EG Sedan - driver-side high beam and radiator fan don't work
Just after some help with my sedans weird electrical problems. my front right headlight (drivers side) main beam won't work, but the low beam bulb will still work. i've tried a new bulb, and the fuses all look fine. as well as this, my radiator fan doesn't work either. i have tried to locate the thermoswitch to jump the connectors, but am a bit confused as to where it is exactly?
after my car warms up on idle, there is quite a bit of steam coming from the radiator, is this a leak, or as a result of my fan not working.. or both?
thanks in advance
thanks in advance
just replace the fuse their cheap anyway. make sure its in the right spot, could be 1 spot over without being noticed.
rad fan switch- the bottom hose on the radiator follow it back to the engine, this is the t-stat theres a connector on the firewall side of it. disconnect it and with a wire or paperclip touch both terminals on the disconnect if the fan turns on bleed the system. if bleeding it doesnt work replace that switch. but if u jump it and it doesnt work hook the fan directly to battery, if it works replace the relay. make sure u check all ur wiring b4 u replace the relay. let us know what the results r.
chuniepatuni
Dec 5, 2006 07:09 PM
