new swap, car shakes when hard acceleration
Old Sep 19, 2010 | 05:36 PM
EGcivic_95's Avatar
Default new swap, car shakes when hard acceleration
oka i have a 94 civic ex coupe, i just put a b18b1 in it lasnight and now i have 2 problems actually not bad but the first is. when i get on it a little bit the car shakes a little bit, and i have a noise from the timing belt area i dont know if it is the water pump going bad or the timing belt being to tight causing a stress on the pump, the belt is real tight. thanks HT
Old Sep 19, 2010 | 05:40 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: new swap, car shakes when hard acceleration
sounds like it could be something wrong with the cv axles for the first issue. I would recheck all the suspension bolts for tightness and motor mounts as well.
Old Sep 19, 2010 | 07:53 PM
300whpej's Avatar
my guess on the shaking is either bad axles or bad mounts. also what is real tight mean on your timing belt?
Old Sep 20, 2010 | 09:44 AM
EGcivic_95's Avatar
sorry, its tight as it maybe tighter then specs im not to sure as in how tight i new with b series, im just trying to pin point little bugs in the motor is all
Old Sep 20, 2010 | 12:36 PM
munchies91crx's Avatar
you should get the tightness check out for sure. too tight is bad. just like too lose. and im gonna say probably motor mounts. make sure they are good and tight.
Shaw14
38
Aug 25, 2009 07:27 PM
SleeperGSR
May 29, 2008 03:27 PM
zdizzle
Mar 7, 2008 08:49 AM
b16_madman
May 28, 2005 06:11 PM
af97civic
Jun 10, 2003 01:31 PM
