Transmission & Drivetrain Gearboxes, Differentials, Clutches
Hard to shift on Transmission
Old Sep 19, 2010 | 04:07 PM
EG6KILIN's Avatar
Default Hard to shift on Transmission
first of all its a gsr trans its hard for me to shift into gears every now and then
sometimes i have to keep playing with it for the gears to go in sometimes i have to shift into second cause first gears wont go in and it takes forever for me to shift into reverse... what could it be???? im not now trans guru lol
Old Sep 20, 2010 | 08:24 AM
speedoptions.ca's Avatar
Default Re: Hard to shift on Transmission
My first guess would be something with your clutch, try bleeding out the clutch system first.
Old Sep 25, 2010 | 09:23 PM
CreativeJza80's Avatar
did you check the trans. fluid?
id swap it out and run full synthetic.
Old Sep 29, 2010 | 01:12 PM
strawdawg001's Avatar
I use to have that issue a while back...turned out that my front passenger transaxial had a seal that needed to be replaced so it was leaking oil...
once i put a quart of oil in it..boom...alll fixed
you might wanna check to see if that's the same case with you
Cameron Ortiz
Apr 26, 2019 04:36 PM
BG-Teg
Jul 18, 2007 01:45 PM
vandersmissenc
Jun 4, 2007 07:44 PM
AwOrKiNpRoGrEsS23
Aug 29, 2006 11:19 AM
fishin9975
May 15, 2004 08:46 PM
