95 Civic EX ABS self checks over and over and over
Old Sep 19, 2010 | 01:08 PM
nastynx2k's Avatar
Default 95 Civic EX ABS self checks over and over and over
95 Civic EX - when starting car (especially after it sits overnight), the ABS will run through its "self check" noise, where the pump is heard. It will then self check, run normal, self check, run normal, self check... in no particular order. Sometimes it will do it while I'm driving, sometimes it won't do it but once (normal operation). No ABS lights are currently on. ABS pump once continued to run by itself for almost 10 seconds before it kicked the light on. Any thoughts/ideas? Personally, I am leaning towards a ground issue/power issue (maybe power is dropping too low at start up, pump continues to initialize, who knows?) Thoughts and ideas are welcome...
Old Sep 19, 2010 | 07:03 PM
Former User's Avatar
Default Re: 95 Civic EX ABS self checks over and over and over
If you jump the service connector, do any trouble codes blink from the ABS light?
Old Sep 21, 2010 | 05:48 AM
nastynx2k's Avatar
Code stored- 1 8 High Pressure System. Accumulator leaking internally?
Old Sep 21, 2010 | 05:58 AM
m00nr0ck Si
May 25, 2009 09:33 AM
twentyhurtz
Suspension & Brakes
Oct 5, 2008 06:43 PM
russianswty
Feb 11, 2007 07:31 PM
josh_c27030
Aug 31, 2006 02:56 PM
klovewell
May 2, 2004 11:23 AM
