Mikayo Fuel Filter is leaking
Old Sep 19, 2010 | 11:11 AM
ek747's Avatar
Icon2 Mikayo Fuel Filter is leaking
I've been trying to change my fuel filter and found a third party part made by Mikayo. However the new part keeps leaking and I'm not sure why.
The filter is supplies with three washers, I've fitted the two large washers around the banjo bolt, however the third seems too small to fit and the original didn't have one on the inlet.
Any help would be appreciated.
Old Sep 19, 2010 | 11:16 AM
Ci-v-iC's Avatar
Default Re: Fuel Filter Problem
Skip the third...not needed.
Old Sep 20, 2010 | 01:19 PM
ek747's Avatar
Default Re: Mikayo Fuel Filter is leaking
I skipped the third washer, however it still leaks so I refitted the old one which is ok.
Can't see why.
Old Sep 20, 2010 | 01:30 PM
Ci-v-iC's Avatar
Aftermarket Fuel Filter is used for many different vehicles...OEM filter never called for a washer on the bottom line, only 2 for banjo.
Mount the Filter on the firewall loosely so you can install the line straight on, then tighten the mounting bolts. Reattach banjo in the last step.
sc34dc4
Oct 29, 2011 12:09 PM
FloridaCivic
Feb 25, 2007 10:08 AM
2kstreetcivic
Jan 18, 2005 07:42 PM
CTR94Joes
Feb 1, 2003 07:02 AM
