Delay in cranking 2002 Accord V-6
Old Sep 19, 2010 | 07:08 AM
racquetgirl222's Avatar
Default Delay in cranking 2002 Accord V-6
Help please. I have 2002 Accord V-6 with 184,000 mi. Perfect. Always started as soon as I hit key. Now sometimes turns over multiple times and acts like it won't start. Turn key off and hit it again, cranks right up. New battery, replaced plugs. Runs great. Doesn't happen every time. Happening more often. No codes. Intermittant.
Old Sep 19, 2010 | 11:31 AM
Str8racn's Avatar
Default Re: Delay in cranking 2002 Accord V-6
Just had the same problem. It was the starter solenoid, so replaced the starter. No more problem =-)
Old Sep 19, 2010 | 02:51 PM
It cranks but won't start. I thought when starter was bad it made a grinding noise. This one sounds fine but just won't start.
Old Sep 19, 2010 | 04:12 PM
HondaPartsHero's Avatar
Technical Hero
next time it does it, make sure the check engine light comes on for a second or two then cuts off (at the same time you should hear a relay click under the dash). If you don't hear it and it won't start its probably the main relay starting to act up.
slabcatcher
Jan 19, 2016 03:37 AM
jwicecold
Aug 6, 2011 10:00 PM
yankeesullivan1
Feb 26, 2011 03:21 PM
gruegrimman
Oct 5, 2007 03:04 AM
chilihotorcold
May 25, 2007 08:41 AM
