Freshly built motor smoking
Ok I just had my motor put together I have a ls with cp pistons wit brand new cp rings eagle ring all gaskets were replaced and I also have crower valvettain with 404 cams today I l started up my far for the first time . Was having trouble keeping the car running cuz I ran into a problem with the distributor but now that's fixed. So I start the car put a basemap on it let it idle to it's at normal temp. Shut it off then I started it here and there for a couple of minutes . Everytime it was running it was smoking like crazy . So I took it for a ride drove it on the street downshifting engine breaking . Then I jumped on the highway did the same thing (letting it rev down ) when I go back home it was still smoking but not as bad is this normal I'm gna do an oil change in the morning hopefully this in normal cuz the guy at the machine told me it's gna smoke I just got to break it in.. Also my a/f reads perfect wen I'm driving so it's not fuel I'm burning it's defly oil
How many miles are actually are on it?
How are you "breaking it in"?
What did you have the gap set at? Its possible the gap is too loose, also the rings may not have been clocked right. Did you have valve seals and guides replaced when you had it rebuilt?
There is roughly 5 miles on the motor .. I had a machine shop do the ring gap and assembly the short block and the seals are good .. They were just replaced wen I bouht the head
i drove it for like 5 miles wat u mean take the block apart>? did the oil change today car is blowing almost no smoke ...gna go drive it some more and see wat happens.....the machine that assembled the motor . he measured everything to spec. he has a good reputation
Before you jump to conclusions and do that though... if it does stop smoking go ahead and do a compression test or even better yet do a leakdown. If that fails then re-ring it
im not gna rip apart the motor again . just got off the phone wiht one of my buddys that has built a couple of motor he said to run the car for another couple of miles ..he said the smoking the motor burning off the assembly lube and the oil on the walls from when the rings where put in
jussayin'.
Why do you feel it necessary to throw it out there that you've talked to so and so and then list their credentials?
you've jumped the gun, had a puff of smoke and jumped ionline asking what could casuse it. When given tips, you just reply with "oh i bought that new", "mr. soso knows what he's doing", this that or the other.
Here, I googled this. Its gonna help you figure out proper engine break in procedure. You say the engine has what, 5 miles on it? Why are you jumping te gun? Endyns way list procedures for the first 1000 miles. Thats 995 more than you have.
Do a compression/leak down test. then make your assumption.
Guy are u ok?? Read the top of the page I said I just had my motor done and it was smoking I asked if this is normal , then u come on here as if the guy who did my motor screwed it up. I said I put about 5 miles on it . If I knew wat the problem was I would of never even started this thread. Don't get bum hurt if my people are telling me different ,
You evidently have no idea what your talking about. No one is saying the machine shop fukced up your engine, we are saying YOU did. Setting the rings is done during break-in and you evidently have no idea how to break in a engine. Keep driving it, maybe you'll get lucky, but if not you have NO CHOICE but to dissassemble it and re-hone the cylinders and put new rings.
calling your buddy up and having him come show you how to properly break-in your engine?
I don't get why so many of you guys do this its like every time someone trys to be a pro and do **** like they know what they are doing then when they **** somethin up its like a light bulb turns on sayin "OH MAN I gotta get home and ask the guys on honda-tech". HONDA-TECH IS NOT A FREE AUTOMOTIVE CLASS PEOPLE. Go to school if you want to learn the proper way to do ****.
Hopefully the smoke stops for you if not congrats on your new chimney on wheels.
clearly, you are here seeking for help but seems like you disagree with everyone's saying so if your machine shop does such a good job why don't you just bring it back to him and ask?
starting a pointless thread calling for help but you dont' wanna listen and thinks you know all that.. just go cry to your mechanic and see what he says about it.
thought to share this with you guys too
read this Break-In Secrets years ago don't know if anyone have ever tried it
i know i would when i rebuild my motor one day and yet i have tried on my bikes seem to work fine then again... i don't ride my bike much and oil change ever 3000km.
http://www.mototuneusa.com/break_in_secrets.htm
if the engine was assembled right and you do the above you'll be fine.
if there is one measurement i'm curious about it's where piston to wall was set
PINKS
Jul 14, 2006 12:23 PM
PINKS
43
Jul 10, 2006 12:14 PM
PINKS
Jul 10, 2006 08:30 AM
