built block turning torque..
Old Sep 18, 2010 | 06:52 PM
cibao2ner's Avatar
Default built block turning torque..
i just finish building my bottom end and i feel its too tight...i had the machine shop make my p2w clearances .0040..all my bearings clearances are withing spec at .0015 according to plastigauge the engine spins nice but i feel too much resistance..at 1/2 way i can lean on it a lil it bit before it spins....any ideas how to check...ive dealt with oem and turbo builds before and they dont feels this tight..
Old Sep 18, 2010 | 06:55 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: built block turning torque..
they can feel a little tight depending on how they honed it. but the best way is to make sure all bearing clearances are dialed. do you trust the machine shop?
Old Sep 18, 2010 | 06:58 PM
cibao2ner's Avatar
yea the machine shop was recomended by my tuner..he told me the guy machines al his engines...all the bearings are within spec i plastigauge one by one
Old Sep 18, 2010 | 08:41 PM
092eg6's Avatar
what piston u using?
Old Sep 18, 2010 | 09:20 PM
cibao2ner's Avatar
manley 81.5mm
Old Sep 18, 2010 | 09:40 PM
lzyga09's Avatar
get a torque gauge and get a reading, The max for the 350 chevy motor that i build was- Max torque is supposed to be 30 pounds max i think and 5 pounds for each cylinder. So i would say around 20 pounds max for a 4 cylinder but every build is different.
Old Sep 18, 2010 | 10:47 PM
d112crzy's Avatar
So you trust that method to be enough?
Did you spec out your crank?
Old Sep 18, 2010 | 11:51 PM
cibao2ner's Avatar
i used std size bearing but the resistance seems to be coming more from the pistons that from the crank...the cranks spun freely with the bearings after the pistons thats when it got tight...might be normal i just dont have another engine to compare too..
Old Sep 19, 2010 | 09:06 AM
d112crzy's Avatar
Ring gaps are good?
Old Sep 19, 2010 | 10:06 AM
EG1834's Avatar
Nothing is hitting right? Is this a stroker or aftermarket crank?
Old Sep 19, 2010 | 12:09 PM
cibao2ner's Avatar
i set my torque wrench to 20lbs and turn it and it didnt click...and the crank is oem..rods are scat and pistons manley...maybe the rings are putting alot of pressure on the walls thats why it feels so tight...turbo motors are run mucj looser so maybe thats the difference..
Old Sep 19, 2010 | 12:47 PM
PyroProblem's Avatar
Spray a little wd-40 in the bores to lube the rings and see if the effort changes. Im thinking you might just be feeling the tension from the rings against the cylinders.
You could also take off the center maincaps and see if it feels different, but if everything is lubed well and within spec,you prob shouldnt feel much change at all.
Old Sep 19, 2010 | 01:30 PM
Scott_Tucker's Avatar
Did you check the crank for straightness before you assembled it?
Old Sep 19, 2010 | 02:08 PM
igorka_91's Avatar
What id do is take all the pistons and rods out putt # 1 piston/rod in and spin it to see if its the one causing problems and then take it out and repeat it with 2,3,4. Try it out. maybe someone has a better idea.
Old Sep 19, 2010 | 05:19 PM
cibao2ner's Avatar
might be the tension..and i lube everything walls, bearings and rings with royal purple assembly lube...and rings were gapped one by one to spec...
Old Sep 20, 2010 | 07:45 PM
b20vtech's Avatar
On a fresh assembled engine it will usually binds more than a motor that's already been broken in, here is a LS motor at 50K miles, crank still took 12 ft. lbs. to turn over, this motor ran perfect.
Old Sep 20, 2010 | 08:12 PM
cibao2ner's Avatar
so if im under 20lbs i should be ok..i did notice the rings had alot of tension outwards...i set my wrenche clicker snap on to 20lbs thats the lowest it goes and it didnt click so my guess its under 20lbs or torque to move it...i would say 15 tops...
powertoweight
Apr 9, 2016 04:17 PM
raverx3m
13
Sep 26, 2010 02:04 PM
gutted
13
Feb 5, 2004 08:03 PM
boostaholic
Mar 5, 2003 09:29 PM
