emissions test failed, 3 codes
i went today to get my emissions tested to register a 2000 civic si i just bought and it said i had the error codes P0122, P0113, and P1337. he said the first two he thought were loose wiring and i could probably fix and he said the third was a honda specific problem and he wasnt able to look it up. any idea what those problems are and how i can fix them? i dont know to much about mechanics but if i could fix them myself and save some money that would help
P.S. on the test is said my car model year was 1999, but on the title it says 2000....?
thanks any help would be appreciated
1st one is the tps sensor, it may need adjusted if its been replaced and not riveted on like the factory one comes,
2nd one is the IAT, its a sensor in your intake tube. just take a look and see if the wiring is ok..
3rd one is the crankshaft sensor...its behind your timing belt cover. sounds like your not too mechanically knowledgeable. youd be better off taking it in thats gonna be an expensive shop visit tho
tps is on the Throttle body, easy enough to see. The IAT is the plug plugged into the intake pipe, also easy enough to see. The crankshaft one might not be so easy.
The first two could be just easy wire problems or just need replaced. Third one is a whole different animal.
You will be slapped if you take this to a shop. Also, check the VIN and make sure the year is what the guy said.
well by honda mechanic you mean dealership..then i would sure hope so. but thats alot of labor to get to that crankshaft sensor, thats easily a 400 dollar repair. i would take the car back to whom you bought it from as ask them for help. what ecu do you have? by aftermarket do you mean its something such as hondata? if the guy installed an intake tube the wasnt specific to your si it may not have the grommet in the tube for the iat sensor..it may be unhooked
the vin matches i already checked it. and im not sure about the ecu, i just know he replaced it, although he gave me the original one with the car. i bought it from a private party though i cant really take it back to him
oh and sorry just a side question, when i turn on my engine i idle at around 2000 rpms for a few minutes, and if i dont let me engine sit for a little bit when i start accelerating i lose all power for a few seconds and my rpms almost drop to 0 then the gas kicks in. will this eb fixed by one of these three sensors?
alright ill look in to the first two tongiht or tomorrow and report back
well that would be why the test says you have a 99 when you really have a 2000. the obdII ecu stores the vin of the vehicle, so you need to have it reprogrammed by honda, or just replace it with the proper one for your car. if your in cali, you will not pass visual if you don't have the proper ecu for YOUR car.
xbinet
Jul 26, 2004 11:48 AM
