My check engine light is on
Old Sep 18, 2010 | 11:58 AM
HondaMan2380's Avatar
Default My check engine light is on
I have a 94 Accord and the check engine light is on but also has a very bad smell coming out of the engine when the light came on. I'm afraid to drive it right now. What is the best course of action to take? Please help!
Old Sep 18, 2010 | 12:12 PM
GhostAccord's Avatar
Default Re: My check engine light is on
Read the codes from the ECU and trouble shoot accordingly.
Self diagnosis is done the same way as on the Civic's & Teg's. I have done it more than a few times myself. There is a blue 2pin/wire connector attached under your glove box/side of the passenger footwell. That is the one that you short to do the SCS self diagnostics.
This is the procedure I used for my 96 Accord.
Here is the blue plastic retainer that is connected to the chassis. The connector is sitting inside this plastic retainer/bracket. (may not be the exact bracket on the 94-95)
This is the two pin connector removed from the retainer. Showing the two female pins where you are to stick the ends of the paper clip or wire.
Old Sep 18, 2010 | 02:13 PM
Thanks for the advice. It came up with a code of 41. How can I find out what that code means?
Old Sep 18, 2010 | 02:59 PM
brianb242's Avatar
code 41 is the primary 02 sensor, what engine do you have? that sensor is located on the exhaust before the cat
Old Sep 18, 2010 | 04:04 PM
I have the F22b. DOHC VTEC!
Old Sep 18, 2010 | 04:09 PM
Thank you both for your help!
Old Sep 19, 2010 | 06:11 AM
Sorcerer's Avatar
a bad o2 would make your car smell like rotten eggs or at least an unpleasent smell.
saintbhts
Jun 9, 2013 06:28 PM
TaMaN86
Jan 23, 2012 07:19 PM
Chavy340
Oct 14, 2011 05:17 PM
Carson89X
Feb 10, 2005 08:17 AM
b16ferio
Sep 27, 2004 04:40 PM
