gsr crank with b16 block?
ok my friend just gave me a set of gsr cp piston and eagle rods and crankshaft from his turbo setup.
now i was wondering if this would fit on my b16a2 block.
tnx
tnx
with some machining possibly. you will have piston/ valve clearance problems because the stroke of a b16 is 77.4mm and a GsR's stroke is 87.2mm. why don't you just use a GsR block? ditch that B16 because you will not make torque numbers on it at all plus for the cost of machining you can pick up a GsR block. use the damn search function on Google or skim through the FAQ's
Man how I wish I can just buy a gsr block. We kind a limited on motors here in Hawaii Maui.
But I also have a ls block will that work?
a b20 block will that possible with 84mm itr piston with gsr crank/rods?
it can be done, but with customized pistons, since GsR rods are longer and will be out of the hole at the deck.
If you want to stroke a b16, get suzuki hayabuza pistons, ls crank, ls rods
what would be my CR with the B16 head?
tnx man
afrikainside
Jan 6, 2012 09:31 AM
