My GSR build... Dyno results
Old Sep 18, 2010 | 05:22 AM
wreckeddc4's Avatar
Icon7 My GSR build... Dyno results
Heres my setup
99 gsr block and head 108000 miles before rebuild
p73 00 pistons std size oem rings
acl bearings and arp rod bolts
buddy club 2 layer hg
arp head studs
blox stg 2 cam and valve springs
brian crower steel retainers
supertech flat valves
3 angle valvejob and new ex guides all new valve seals
decked only enough to ensure its flat
golden eagle cam gears
skunk2 intake manifold gasket matched by me
blox 68mm cast tb
skunk2 composite fuel rail
id1000cc injectors
b&m fpr
walbro 255
E85 from the pump
Xenocron tuned
First motor build... what you guys think?
Old Sep 18, 2010 | 05:28 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: My GSR build... Dyno results
very nice looking graph, good power numbers too. What kind of dyno was it tuned on?
Old Sep 18, 2010 | 05:48 AM
wreckeddc4's Avatar
Thanks, I believe it was a dynapack dyno
Old Sep 18, 2010 | 07:45 AM
NA_B_FTW's Avatar
Nice numbers
Old Sep 18, 2010 | 08:43 AM
fv8s's Avatar
E85
Old Sep 18, 2010 | 11:44 AM
mar778c's Avatar
Community Builder
Community Influencer
Nope, I believe Chris has a dyno dynamics model.
Old Sep 18, 2010 | 03:03 PM
egb18c5's Avatar
nice numbers, what header?
Old Sep 18, 2010 | 07:16 PM
johnfrancis's Avatar
nice
Old Sep 19, 2010 | 03:45 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
I wish I had a local e85 pump :/
good numbers man
Old Sep 19, 2010 | 07:09 AM
b18c5 beto's Avatar
what type of headers did you have just curious? did u have a light whight flywheel or performance clutch in your motor becuse i have something very sim·i·lar to your set up.?nice # to.im trying to make 220
Old Sep 19, 2010 | 08:15 AM
ekcoupeh22's Avatar
why does it say flywheel power on the chart not wheel power?
Old Sep 19, 2010 | 12:36 PM
DDTECH's Avatar
solid numbers from chris as always.. -
Simple.. build that produces good numbers, now, track that baby and tell us the et / mph trap.
Old Sep 20, 2010 | 08:46 AM
NinJa_FLiP's Avatar
im with him.. was that a mistake?? also im curious why u used 1000cc injectors.. thanks
Old Sep 20, 2010 | 12:31 PM
wreckeddc4's Avatar
I have an rmf narrow rep header for those that were curious. Also it was a dyno dynamics dyno, and that it calculates flywheel hp and tq, so whp will be lower than 210. But the car still feels strong and I have traction issues already. I went with the 1000s by chris' advice from xenocron, due to there quality and ease of tuning, no matter what my power goal. Also there will be no need to replace them if I do build a bigger motor. Im using a cometition clutch stage 2 street disk and pressure plate and there 12lb steel flywheel. I also use an omni power clutch master cyl.
Old Sep 20, 2010 | 01:36 PM
xenocron's Avatar
Dyno Dynamics has a "shootout" or comparison mode where the graph say flywheel HP....just like a Dynapack Dyno.
In fact, most dyno are measuring power to the Flywheel, whether they display that on their graphs or not. This just replicates as close as I can get to what a local Dynojet might read...which of course is what 80% of the people out there are concerned with, first thing when they come off the dyno
I was very impressed with this car, and young Josh here. His ability to put a setup like this together HIMSELF, would put most of the "shops" to shame that I see.
Old Sep 20, 2010 | 04:40 PM
wreckeddc4's Avatar
Icon4 Re: My GSR build... Dyno results
Thanks very much Chris. And thanks again for all the tech support and the awesome tune.
Old Sep 20, 2010 | 04:50 PM
njegos18t's Avatar
good job
Old Sep 20, 2010 | 05:02 PM
Aesthetic Gains's Avatar
Dos Pupusas
Props to you man! Nice job putting it together!
And Chris at Xenocron always helping people out. I was there last friday buying some stuff. Great person to do business with!
Old Sep 20, 2010 | 06:17 PM
Sparkles's Avatar
Very nice, thanks for sharing
Old Sep 24, 2010 | 06:25 PM
tu417's Avatar
niceeee
Old Sep 25, 2010 | 06:02 AM
dntnedvtec's Avatar
Good numbers.
Old Sep 25, 2010 | 03:30 PM
Uncle Dave's Avatar
Nice job on the build and Chris as always makes his customers very happy with his tuning.
Old Sep 25, 2010 | 03:53 PM
xSteve_Ox's Avatar
Simple build, strong numbers. I like
negusjuda
23
May 26, 2012 02:42 PM
lukerc45
Aug 30, 2011 12:32 PM
fknfast
16
May 28, 2011 02:28 PM
Slepton
29
Aug 12, 2010 06:13 PM
Easyslider01
17
Jul 12, 2005 09:19 PM
