cams for all motor buddy club or bisimoto?
Ive been trying to find some good cams for my all motor build. I want a loop nothing way to aggressive. heres my set up
cp pistons 11.5;1
b16 head all supertech for the head flat top valves
eagle rods
gsr transmission
gsr new OEM pumps
acl race bearings
still need to buy list
buddy club 4 way adjustable cam gears
skunk2 intake
throttle body
clutch
flywheel
buddy club exhaust
ls vtec kit
hondata tuning
Let me know what you think.
cp pistons 11.5;1
eagle rods
gsr transmission
gsr new OEM pumps
acl race bearings
skunk2 intake
throttle body
clutch
flywheel
buddy club exhaust
ls vtec kit
hondata tuning
get a 3 inch exhaust makes more power on high compression builds...and bisi has custom cams im gonna be running bc4 cams but they are peaky cam selection depends on compression intake manifold and header...bc4 like short runner intake manifolds..and like to rev to 9500...if you havent bought them do a lil more reasearch and be honest to yourself on what type of power u want...mines is street car that i drive maybe once a week...but never sees under 5k rpms when i drive it...
Bisi products are all top notch!
Are you drag racing or road racing.
250"whp?" Do you have port work? Is it 2.0L+?
A REAL 250whp b-series is not just a peice of cake. I'm not trying to burst your bubble, but you're gonna need an agressive cam to produce those numbers. Either way Good Luck. I think Bisi is what you need, cam/header...
for 250whp ur gonna have to plan this a lil better...have a 2l block higher compression and a head pakckage that works together..intake manifold cams and header...look into endyn..he built a 2l with 267whp for honda tuning....
I am going to run it at the track a few time to see what it can do. my buddy dad owns a machine shop were going to port match the head and mill the head a little bit
95lsteg9116
Jan 30, 2010 01:54 PM
