Switching wastegate springs after tune, retune needed?
Old Sep 17, 2010 | 03:37 PM
Sordz's Avatar
Default Switching wastegate springs after tune, retune needed?
Maybe a simple question but if I tune my car to say 15-18psi with a 10psi wg spring, then switch to a 7psi spring after would the boost controller have to be adjusted(boost solenoid controlled by computer) or need a retune?
Car now is at 10psi with 390whp and is being tuned for higher boost around 500-550whp in a few days and I wanted to try and hook 2nd so would need a lower spring for lower boost in 2nd and dont have time to switch it prior to tune.
thanks
h22
neptune rtp
62mm turbo
44mm wg
e85
Old Sep 17, 2010 | 04:05 PM
TheStig187's Avatar
Default Re: Switching wastegate springs after tune, retune needed?
U should be good the 7psi spring just mean that 7 psi is ur min amount boost u can run as long as u got a boost controller u can always set a grater amount, like 15-18psi, so if its tune for 10psi i would recomend u get it tune for 15-18psi.
Old Sep 17, 2010 | 05:37 PM
Garage 808 Hatch's Avatar
more than likely your boost levels will be lower due to the lower spring pressure.
1990hondaHF
Jan 16, 2008 11:57 AM
vg7z
Sep 20, 2006 08:27 PM
RTW DC2R
Mar 24, 2006 06:33 PM
shingles
Jan 24, 2003 01:58 AM
zojirushi
Jan 23, 2002 04:42 PM
