Switching wastegate springs after tune, retune needed?
Maybe a simple question but if I tune my car to say 15-18psi with a 10psi wg spring, then switch to a 7psi spring after would the boost controller have to be adjusted(boost solenoid controlled by computer) or need a retune?
Car now is at 10psi with 390whp and is being tuned for higher boost around 500-550whp in a few days and I wanted to try and hook 2nd so would need a lower spring for lower boost in 2nd and dont have time to switch it prior to tune.
thanks
h22
neptune rtp
62mm turbo
44mm wg
e85
thanks
h22
neptune rtp
62mm turbo
44mm wg
e85
Re: Switching wastegate springs after tune, retune needed?
U should be good the 7psi spring just mean that 7 psi is ur min amount boost u can run as long as u got a boost controller u can always set a grater amount, like 15-18psi, so if its tune for 10psi i would recomend u get it tune for 15-18psi.
vg7z
09-20-2006 08:27 PM
zojirushi
01-23-2002 04:42 PM
