coil spring compressor optional when removing old suspension coils?
Old Sep 17, 2010 | 02:08 PM
akcapr's Avatar
Default coil spring compressor optional when removing old suspension coils?
I purchased some progress coilovers for my civic eg hatch, and i am wondering if i can get away with taking out the old suspension without using spring compressors. I have read some write ups that say you must compress the old spring before removing it or to take the cap off or something, and some write ups dont say anything about it. And if i dont compress it what will happen... i wont be able to take it out?
thanks
Old Sep 17, 2010 | 02:15 PM
panchlow's Avatar
Default Re: coil spring compressor optional when removing old suspension coils?
ur probally chop off your hand..
i kno that the front ones you can take off easily with out a compressor.
Its still going to snap but jst try to keep your hand away from it.
The back ones have more pressure, so i did use a compressor....
you can rent one for cheap at autozone or kragen's...
Old Sep 17, 2010 | 02:32 PM
akcapr's Avatar
thanks. also, when i was trying to detach the rear shock from the lca, and i was undoing the 14 mm bolt that goes througt the lca, it was really stuck on there. i gave it all i got and it snapped the bolt head off- any advice? im thinking im just gonna drill all the way through it and then put a new bolt in..
Old Sep 17, 2010 | 03:39 PM
canadaek's Avatar
to remove the complete strut you don't need a spring compressor . to remove the spring from the strut you need one unless you want to die. use a sawzal or cut off wheel to cut the other side of the bolt also . then it might be better to get a new bushing and bolt from honda . it can be hard to press the old bushings out but i think it would take forever to try and drill it out.
Old Sep 18, 2010 | 04:32 PM
panchlow's Avatar
go to the junk yard and get another one.
and use WD-40 next time. haha
Old Sep 19, 2010 | 05:03 PM
Jockone's Avatar
Bolts tend to get rusted solid to the sleeve in the bushing,do as another poster said and cut the other side of the bolt for removal and you can most times remove the last threaded bit with vicegrips.
As for the strut removal use a compressor to avoid bodily injury,it's not worth the risk.
boostedefhatch
Apr 6, 2009 09:22 PM
GraphiteMW
Mar 27, 2007 05:25 PM
Elemental
Oct 10, 2004 08:02 PM
b18hatch
Sep 15, 2003 11:28 AM
SkylineGTR
Dec 25, 2002 03:08 PM
