CEL might not be working?
Old Sep 17, 2010 | 07:51 AM
Momentum's Avatar
Default CEL might not be working?
I put a JDM D15B into my OBD2B hatch, now the engine won't start and there is no CEL's... So I thought I'd test to see if the CEL actually works...
So I turn the key, and the only lights that come on are: Oil Pressure, E-Brake, SRS. (I have aftermarket wheel, e-brake is up, and the stock oil pressure sensor is not hooked up)
Other than those three, no lights light up at all, not even for a second. So I thought I'd try the CEL on the cluster in my other hatch, a bunch of lights light up for half a second, but not the CEL...
Old Sep 17, 2010 | 07:55 AM
D Griff's Avatar
Default Re: CEL might not be working?
Maybe it's an ECU or wiring problem? Hopefully someone can chime in with some answers.
Old Sep 17, 2010 | 08:19 AM
Jimster480's Avatar
did you change any wiring? Because the OBD2B cars are wired very differently. Does the car even crank? Have you tried jumping the service connector?
Old Sep 17, 2010 | 08:38 AM
Momentum's Avatar
The car cranks, but won't fire. I jumped the service connector and still nothing.
I'm using my obd2b harness, with a jumper harness to a p06 ecu. I rewired my dizzy to mate to my obd2 harness using a diagram from
Ff-squad. I'm using my obd2 alternator. I did the 3 wire/2 wire iacv fix.
Old Sep 17, 2010 | 09:52 AM
virgineg6's Avatar
so what ur saying is that u took the cluster and put it in another hatch and the cel still didnt come? not trying to make u sound dumb but if the problem follows a part it prolly the part. swap bulbs on the cluster to 1 u know works like the turn signal then try again. as for it not starting do u have spark and fuel?
Old Sep 17, 2010 | 09:05 PM
Momentum's Avatar
No.
The car this topic is about is a 2000 Hatch with an SiR cluster.
When i said i tried to check for the CEL in my other hatch, i just meant turning the key to see if the light came on... different car, different cluster. My other hatch is a 98 with a USDM SI cluster.
Old Sep 18, 2010 | 11:10 AM
Jimster480's Avatar
Well if you jump the connector and nothing comes on then the wiring is fkd up somewhere.
Old Sep 18, 2010 | 11:26 AM
virgineg6's Avatar
lol ight now i look like a dumba**, id still try swappin bulbs 1st since that would be a real easy fix, but from there its either wiring or the ecu. u sure ur jumping the right connector?
Old Sep 20, 2010 | 01:10 AM
Momentum's Avatar
Well, the light doesn't work for sure.
I bought hondata s300, which showed me that I have no codes, but I turned the knock sensor on and then hondata said I had a code, but nothing in the cluster... Looks like I'm getting a new bulb! Anyone know which bulb this is?
crona100
Jun 6, 2015 07:14 AM
Crashmaster91
Jan 31, 2013 02:23 PM
syler
11
Apr 15, 2007 01:01 PM
SH^ftw^01
Mar 27, 2007 02:02 PM
t0p_sh0tta
Nov 19, 2002 07:12 AM
