stripped out tensioner bolt
Old Sep 16, 2010 | 10:59 PM
psychotech's Avatar
Icon6 stripped out tensioner bolt
What size helicoil do I need for the timing belt tensioner hole on a b17a1? Or could I just re-tap the hole?
Old Sep 17, 2010 | 07:35 AM
lsd96teg's Avatar
Default Re: stripped out tensioner bolt
Take the bolt out and match the bolt to a helicoil kit, I had the same issue.
Old Sep 17, 2010 | 10:52 AM
psychotech's Avatar
Yeah, I'm about to head to osh and match the threads in their bolt section.
Old Oct 8, 2010 | 12:19 PM
psychotech's Avatar
Icon3 Re: stripped out tensioner bolt
My dad was thinking about getting a longer bolt to put in the hole but I'm not liking the idea much...plus it seems like a whole lot of meat would be taken out if i did the helicoil route.....I'm starting to think about taking it to a machine shop....any ideas or reassurance would be appreciated, thanks.
Old Oct 8, 2010 | 12:46 PM
komat's Avatar
helicoil it or the better solution would be time insert
Old Oct 8, 2010 | 01:00 PM
lsd96teg's Avatar
Dang after a month its still not done??? This is like a twenty minute job, match the bolt up to a helicoil kit, don't drill any farther or use a longer bolt. Thats just dumb, just make sure you do not over tirghten the bolt. If you over tighten it, you will have the same issue.
Old Oct 15, 2010 | 11:56 AM
psychotech's Avatar
Icon2 Re: stripped out tensioner bolt
Yeah, I have problems with coming up with the money for parts. got the job done a while ago. thanks for the help. would anyone happen to know if the Tensioner spring comes with the timing belt kit? I hope so...the reason everything was stripped out is the previous owner used a prybar and brute force to get the tension on the belt....had no spring on it....
aznryd3r
Apr 25, 2006 08:21 PM
BROKE.eg
17
Nov 25, 2005 08:19 PM
Renegade
15
Sep 22, 2003 06:28 AM
88 rex
Jul 24, 2003 02:18 PM
