450 hp B-series keeps breaking oil pumps - which crank pulley???
Old Sep 16, 2010 | 07:24 PM
CivicSD's Avatar
Icon2 450 hp B-series keeps breaking oil pumps - which crank pulley???
i'm runnin the performance plus $180 crank pulley, its supposed to be harmonic balancer "ctr race spec"
Shattered two oil pumps in the last six months.
Should I switch to the ATI pulley? Or Fluidamper?
Your thoughts?
Thanks
Old Sep 16, 2010 | 07:27 PM
cibao2ner's Avatar
Default Re: 450 hp B-series keeps breaking oil pumps - which crank pulley???
oem pulley....or either fluid or ati are fine...
Old Sep 16, 2010 | 07:38 PM
Garage 808 Hatch's Avatar
ATI, and be done with it, or an obd1 oem
Old Sep 16, 2010 | 10:28 PM
TheShodan's Avatar
Moderator
Old Sep 17, 2010 | 08:24 AM
[Ennis_D]'s Avatar
Old Sep 17, 2010 | 03:25 PM
rat city rex's Avatar
oem.
Old Sep 17, 2010 | 03:38 PM
91jdmhatchback's Avatar
Have you thought about checking the oil pump gear to crankshaft clearance? If your engien has been rebuilt you could have issues with excessive pressure being placed on the pump gears.
A pully will not shatter gears, theres and inharent problem with the engine. Please don't turn this into a ctr pulley's blow motors.
Old Sep 17, 2010 | 05:50 PM
boostek9's Avatar
oem or bust!
and yes a pully can cause gears to shatter. most of the aftermarket or ctr pulleys are not balanced well and cause vibration in the crank which causes pump failure...based on experience!
Old Sep 17, 2010 | 06:10 PM
Charlie Moua's Avatar
what ever happened to "shaving" the crank pulley?
I know someone use to offer that service many years back but I don't ever hear about it anymore....
Did it work well or not well?
Old Sep 18, 2010 | 12:27 AM
bOoStEd_180e's Avatar
where or how did your pump break?
Old Sep 18, 2010 | 05:32 AM
QUICK8CIVIC's Avatar
check your relief valve..
Old Sep 18, 2010 | 12:02 PM
Blown90hatcH's Avatar
The first thing to check is of course the motor when building it. However, I know that pulley's do in fact contribute to broken gears.
ATI or Fluidampr to the original poster and be done with it.
Old Sep 18, 2010 | 02:36 PM
racemycivic's Avatar
I shattered 4 oil pumps with a ctr spec pulley strait from honda. I switched to an oem gsr pulley and havent had a problem since and i have witnessed other cars with the same problem on boosted setups, take that pulley off asappppppppp
Old Sep 19, 2010 | 12:53 PM
Based on your thoughts of a crank pulley causing a oil pump to fail. Why is there not endless threads about lightweight flywheels destroying engines/oil pumps? It's the same thing just on the other side of the block, and with WAY more weight swinging around.
Old Sep 19, 2010 | 02:56 PM
Not anywhere near the same. You flywheel just spins round and round. Its soild. Your stock crank pully has rubber in it to help dampin any vibrations. When you have a aftermarket pully that is just some spun alum or whatever it dosent suck up any of the vibrations and sends the vibrations down your crank.
Old Sep 19, 2010 | 04:15 PM
Because you have two things on that side of the crank that you do not on the crank pulley side. You have the clutch to help balance and you have to transfer all that vibration/harmonics through the mains/girdle. With the crank pulley, there is nothing there to support it. All the vibration/harmonics are present and the oil pump takes the beating.
Old Sep 19, 2010 | 08:21 PM
Camsshaft's Avatar
Isn't a lot of oil pump failure due to very harsh clutch engagement also? I remember reading some years back about the "shock" of unsprung clutches causing it also. It was an article talking about S2000 driveline and Tatsuru Ichisima, the owner of Spoon, was going on about S2000 driveline. But yes of coarse an oem or ati is better than a **** chung lightweight pulley. just something else to think about I guess
Old Sep 20, 2010 | 09:37 AM
ShanghaiOC's Avatar
Is this a stock oil pump? I've seen a few cars over 400hp have stock oil pumps give out. Get a better damper & oil pump then call it a day
Old Sep 22, 2010 | 03:21 AM
MidShipCivic's Avatar
Balance your rotating assembly the pulley isn't doing anything wrong the assembly is out of balance. IMO.
Old Sep 22, 2010 | 03:54 AM
Honda Bull's Avatar
OEM, ATI, or Fluidampr. You shouldn't be using anything else.
Old Sep 22, 2010 | 04:18 AM
Oh sure, just don't self willingly ignore the discrepancies.
Add a light weigh clutch/fly assembly to the opposite of the crank that has less mass so increases pulsations blame it on just the pulley it's very rational .
Old Sep 22, 2010 | 05:13 PM
Its easy to have unwanted harmonics from your clutch assy especially with oem diameter metallic clutch setups.metallic clutch pucks in discs are not balanced and can also cause vibrations as rpm rises.these vibrations will run towards the crank pulley past the oil pump thus, a good damper is a wise investment.
Old Sep 22, 2010 | 06:45 PM
[Ennis_D]'s Avatar
You are talking about "dunkd". I have one of his pulleys but have never used it. It has a chip on the outer rim but he gave me his word that it still balanced out. Got it on the low but now it collects dust.
Here is the link if interested: Shaved/Lightened Crankshaft Pulleys, OEM B16 GSR ITR LS
Old Sep 22, 2010 | 07:03 PM
a1320honda's Avatar
I used to be one of those hardcore "CTR pulleys cant destroy an oil pump" guys. Everyone told me time and time again to yard that thing off, but i loved the fact my motor revved like 600cc bike. Until one day i was pulling on the car hard and.....oh wow, my oil pump shattered and led to the demise of my motor. Since then its been an OEM 2000 Si balancer and havent had a single sign of wear on any of the bearings or oil pump in my built motor. BAN the CTR lol
Old Sep 23, 2010 | 05:27 AM
kyden's Avatar
normal ctrs came with a regular pulley, its the n1 that only has the alternator drive.
