leakdown test proceedure...
Old Sep 16, 2010 | 03:23 PM
blackeg's Avatar
Default leakdown test proceedure...
just wondering if i've been doing this all wrong over the years..
i get the motor warm and set cyls to tdc.
when i hook up the gauge to the cylinder i start at 100 psi but it usually drops down to 90 something. if i leave it at that i get readings in the 10-20% range.
now, once the cyl is pressurized if i adjust the psi back up to 100, my leakdown goes down about 10%.
so, do i leave it like the first situation with 100 psi when i hook it up and thats the result, or do i put the psi back up to 100 from 90 something after i hook it to the cylinder...
this particular motor i know to be very healthy, it cranks over 208-210 psi on 9.3:1 static and pulls 23.5" at idle
Old Sep 16, 2010 | 10:08 PM
v8killaz's Avatar
Default Re: leakdown test proceedure...
i dont know how you do it but i have a harbor freight leak down tester and all i do is set my compressor to 100 psi
then turn the **** on the tester counterclockwise then slowly turn it clockwise till it says set on the gauge, i dont look at psi
then i plug it in the cylinder and tells me the leakage. and i can crank the pressure a bit higher to see where its coming from
Old Sep 19, 2010 | 12:08 PM
blackeg's Avatar
well once i connect tester to cylinder the psi drops below 100, which would effectively take the needle off set and put it up toward 10%. set only works as a reference point if there is 100 psi in the cylinder....right?
Old Sep 19, 2010 | 04:01 PM
v8killaz's Avatar
well once its at set and you connect it then it will go to 10% or up
and thats ur cylinder leakage
Old Sep 19, 2010 | 04:19 PM
newschool's Avatar
Yes, you need to further turn the **** after the base pressure "sets", i.e. have it at 100psi input pressure once connected.
Old Sep 20, 2010 | 01:14 PM
blackeg's Avatar
right, thats kinda what i thought once i got into how it really works. i have a little leak from the connection where the gauge hooks to the hose going into the spark plug hole, i can hear it hissing a little
markopolo
Mar 5, 2017 06:16 AM
flaxx0r
Oct 14, 2008 10:31 PM
PreludePhill
May 25, 2006 02:38 PM
92integraVTECgsr
Nov 20, 2005 01:02 PM
white91rex
Nov 12, 2005 07:46 PM
