long motor life.
Old Sep 16, 2010 | 03:22 PM
jlowellintegra's Avatar
Default long motor life.
While my motor is out, what are some things that i should replace like the most important to least important. Im guessing some things are...
oil pump
water pump
plugs/wires
gaskets/seals
what else???????...without spending a bundle and easy installation thanks!!
Old Sep 16, 2010 | 03:40 PM
lsd96teg's Avatar
Default Re: long motor life.
water pump, tbelt, oil pan gasket, headgasket, valve cover gasket. Those are a few that I would do, all of those can be done with the engine in the car though. How many miles are on your engine?
Old Sep 16, 2010 | 03:54 PM
its one from a "jdm depot" so they say 30-50k
Old Sep 17, 2010 | 07:30 AM
lsd96teg's Avatar
I would just inspect it, put new spark plugs and fluids in it and run the thing then. That is not very many miles. You may wanna consider doing a Tbelt though just for piece of mind.
Old Sep 17, 2010 | 11:03 AM
grey_LS's Avatar
synthetic oil ;D
Old Sep 17, 2010 | 01:27 PM
dntnedvtec's Avatar
Originally Posted by grey_LS
synthetic oil ;D
Unless your running AutoX, or some sort of racing, I wouldn't run anything anthing but normal honda engine oil. 5w-30.
Old Sep 17, 2010 | 02:06 PM
lsd96teg's Avatar
Your reasoning behind this?
Old Sep 17, 2010 | 07:30 PM
dntnedvtec's Avatar
I think it is a waste of money. I use to run synthetic, until I got broke, and started to use regular oil. I didn't notice a change in performance at all. Seemed like it ran better.(probably) But as I was spending all that money on synthetic oils, my car ran just as good on syn. than regular oils. IMO
Old Sep 17, 2010 | 08:03 PM
delsolproblems's Avatar
Depends if the motor being out means you're taking it apart and if so, how much. If you're not taking the head off anyway, having the motor out won't necessarily help with changing the HG. You could leave the timing belt on since the only step in that process you have to perform when pulling the motor is disconnecting the mount. Taking the motor out whole will open up the clutch & flywheel if MT. You leaving the tranny in? Post how far you're planning on disassembling the engine and get a set of all new coolant hoses.
theseventhsun
Mar 12, 2016 09:50 PM
Nshouse0003
Jun 9, 2011 11:29 AM
exist12
Jul 9, 2009 04:59 PM
hondax
Jun 16, 2004 01:05 AM
TheSwift1
Feb 26, 2003 07:10 AM
