1992 Honda accord audio help
Old Sep 16, 2010 | 02:09 PM
beeasy12's Avatar
Default 1992 Honda accord audio help
92 accord ex
If I pull my stock radio and install mounting kit, the wires for the old radio could be used for new deck?
Also, can I use the stock wires for new after market speaker and those would be 5 by 7?
The front would be...?
Thanks for help and yes a am audio noob.
Old Sep 16, 2010 | 04:03 PM
joeymc13's Avatar
Default Re: 1992 Honda accord audio help
You could use your stock wires from behind the radio, but it's easier just to get an aftermarket radio wiring harness for your car. If you use the stock harness, you're going to have to cut it off, and hardwire the new radio, but the colors won't match up, you'll have to get a diagram. If you cut, cut the wires individually, there will be a wire that has voltage in it, and a ground wire, if they touch, you will blow a fuse.
Your front door speakers are 5 1/4", and your rear deck speakers are 6x9".
Old Sep 16, 2010 | 04:51 PM
beeasy12's Avatar
and changing the speakers out? just unplug and then plug speakers
Old Sep 16, 2010 | 04:58 PM
joeymc13's Avatar
Not really. There will be a grey plug on there that won't fit on the aftermarket spkrs. You can either cut off, and splice in some spade connectors to fit on the speaker terminals, or just buy speaker harnesses for your honda, usually not very expensive. These harnesses will fit onto that grey plug from your car speaker, and the other ends will fit right onto your new speakers.
If you cut the grey plug off, you need to make sure you don't get the polarity reversed (the positve wire and negative wire). Its fine if all speakers are wired backwards, but if just some spkrs are wired one way, and swithced on others, you'll lose sound quality.
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Dead CIVIC
Audio / Security / Video
Jan 23, 2015 06:24 PM
Muydos
Sep 1, 2012 09:18 PM
lee0149
13
Jan 7, 2009 08:47 PM
pwrofdrm
Feb 18, 2004 05:27 PM
