EK rear disc brake conversion Q's??????
Old Sep 16, 2010 | 01:28 PM
92hondaswap's Avatar
Default EK rear disc brake conversion Q's??????
hi I have a '96 EK Sedan and I just bought a rear Disc suspension from an Acura integra to do a disc brake conversion. I'm being told that I only need to put the integ Hubs on mine without the need of replacing the whole swing arm, and also that I will need a '99 Civic Si E-brake cable to make it work because my E-brake cable will be too long.. How true is this???
Old Sep 16, 2010 | 01:43 PM
jonesEK's Avatar
Default Re: EK rear disc brake conversion Q's??????
I'm not sure how true it is.. But I dont see a problem if it is too long I think you should worry more if it is too short.... I'll measure some that I have in my garage if you measure your integra cables
Old Sep 16, 2010 | 02:00 PM
B18CivicEJ8's Avatar
Your drum ebrake cables will not work. You will need 99-00 Civic Si cables.
Old Sep 16, 2010 | 02:05 PM
98civdx's Avatar
Master Detailer
There's been people that have used integra lines also, but i dont think they mount up perfectly.
Yes you can switch just the hub, but it is easier to drop and switch the entire trailing arm.
Old Sep 16, 2010 | 05:35 PM
scar96's Avatar
Hi I did this swap on my 96 EX sedan.
Here is whats involved:
-You are better off changing the whole arm cuz its only couple of bolts.
-You will definitely need 99 Si cables becuz the integra ones are longer and the Si ones are perfect fit.
-It is recommended to get the 99 Si prop valve but not required.
-Calipers and brake pads are all the same for 99Si, Integras and Del Sols.
-You are going to need Honda Brake fluid cuz you are gonna bleed your brakes after. You could go to pep boys but nuttin beats OEM.
Old Sep 16, 2010 | 07:49 PM
Ok thanks a lot guys!! the Teg suspension I got doesn't have the E-brake cable but from your info I sure don't need it either.
Old Sep 16, 2010 | 08:00 PM
98civdx's Avatar
Master Detailer
Also, you do not need a 99-00 si prop vavle, you can use them from 96-00 civic dx, hatch/coupe, hx as well as si.
Old Dec 27, 2012 | 11:08 AM
nickart42's Avatar
If I want to put aftermarket rotors, calipers, and pads, what oem parts, tool, supplies, etc. will I need for an 96 hatchback? What year integra should I look into?
Old Dec 27, 2012 | 11:26 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-put-x-brakes-your-96-00-ek-civic-revised-upgrade-chart-1513752/
Old Dec 27, 2012 | 12:04 PM
Fliptard's Avatar
Might as well replace the bushing and bearings while it's all apart too, so you don't have to worry about it.
Old Dec 27, 2012 | 04:46 PM
beecee18's Avatar
1996-2000 Cx or Si only,
the valve needs to originate from non ABS vehicle.
Old Dec 27, 2012 | 04:52 PM
jbpnoman's Avatar
98 DX sedan has the same prop valve, beecee.
Old Dec 27, 2012 | 04:56 PM
beecee18's Avatar
good to know
Old Dec 27, 2012 | 05:03 PM
jbpnoman's Avatar
Originally Posted by beecee18
good to know
yeah man, I can't tell you how satisfied I was to find that out when I was doing my conversion.
'96-EJ6Hatch
32
Mar 18, 2012 05:21 PM
singh88
Suspension & Brakes
Apr 26, 2009 02:47 PM
JLEK
17
Jun 11, 2007 09:58 PM
Curbow_USMC
Mar 2, 2007 08:25 PM
powerslide360
Mar 20, 2005 07:30 PM
