Function7 Lower Control Arms and Subframe Brace
Designed for the extremes of racing use, all of our lower control arms are precision machined out of 7075 aluminum for maximum strength and then treated for corrosion resistance.
Every arm is tracked in every step of the manufacturing process, and each arm is individually serialized and barcoded for quality assurance.
For prices and applications: Function7 Lower Control Arms
The Function7 Rear Subframe Brace kit for the 96-00 Civic provide reinforces the rear crossmember of the chassis providing improved handling and steering response. Like all Function7 products, this computer-designed brace has been thoroughly tested and refined on the racetrack to improve the handling of the Honda Civic.
Made out of a solid block of 7075 aluminum (about 20% stronger than 6061), the one-piece construction of the brace is designed to provide the maximum rigidity with the minimum weight.
The integral sway bar mount adds rigidity to the structure of the car and will accommodate all factory and most aftermarket sway bar kits using almost any off-the-shelf universal sway bar bracket kits.
A standard hardware kit is included with the rear brace, and includes reinforcement plates to prevent frame tearout, which is a common occurence on the EK Civic chassis when used with large aftermarket sway bars.
For prices and applications: Function7 Rear Subframe Brace
Hey I left a PM but could I get a quote of a total price on you're Rear Subframe Brace with Integral Sway Bar Mount & the Ultralight Lower Control Arms for my 02 civic EX 2DR shipped to 95337, thank you.
70383roadrunner
Honda Civic (2001 - 2005)
Mar 30, 2018 06:37 AM
