Anyone ever used a 45 trim T3/T4E?
Old Sep 16, 2010 | 04:17 AM
grandtheftlunchbox's Avatar
Default Anyone ever used a 45 trim T3/T4E?
I'm looking at one and it seems perfect for my power goals. But turbine wheel specs aren't listed, and it seems like a relatively uncommon turbo. All I can find is ".58a/r exhaust, .60a/r compressor, 45 trim, up to 350hp, great low end." Anybody know what the turbine specs are for this turbo? I'm running a DOHC ZC and I need to know if the turbine wheel will even flow enough for 300hp on a d-series. Thanks ladies.
Old Sep 16, 2010 | 11:48 AM
Default Re: Anyone ever used a 45 trim T3/T4E?
No one? Someone out there has to have used one of these things.
Old Sep 16, 2010 | 01:43 PM
welfarepc's Avatar
the ebay "57 trim" turbos are .50 AR 44 trim compressor housings, with a .63 AR turbine housing.
it should be pretty close to what u are looking at.
Old Sep 16, 2010 | 04:26 PM
nice, thanks for that tip. Anyone got any specs on the turbine wheel?
Old Sep 16, 2010 | 06:29 PM
I did some more digging and found that the turbine wheel is a stage II 69 trim. What would you guys say are the limits of a stage II wheel with a .58a/r housing? I'm thinking that it seems like a good compromise between good spool and decent top end somewhere around 300whp. I don't plan on going any higher than that.
T3k C
Aug 5, 2008 11:29 AM
Hulkmanj99
Oct 14, 2004 12:49 PM
ModenaTwinTurbo
May 22, 2004 07:14 PM
underpressure02
Feb 10, 2004 07:26 AM
specie
Jan 15, 2003 06:15 PM
