JDM B18C (GSR/SiR-G) block/B16 PR3 head: Will TYPE-R ECU work!?
Old Sep 16, 2010 | 12:48 AM
-__-'s Avatar
Default JDM B18C (GSR/SiR-G) block/B16 PR3 head: Will TYPE-R ECU work!?
I'm going to be dropping in a motor i'm rebuilding and was wondering if this ECU would be good. it's a 97 Spec ITR ECU. P73-003
The block is a JDM B18C (GSR/SiR-G) NOT TYPE-R!
The head is a B16 PR3 head.
this setup will run about a 10.5 Compression ratio.
so i was wondering if the Type-R 11:1 compression ratio ECU will run this motor well?
If anything it will run it better than my USDM GSR computer.
your thoughts? thanks a lot.
Old Sep 16, 2010 | 09:49 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: TYPE-R ECU!?
It should work pretty good still, and still have the higher redline
Old Sep 16, 2010 | 05:13 PM
-__-'s Avatar
Default Re: JDM B18C (GSR/SiR-G) block/B16 PR3 head: Will TYPE-R ECU work!?
k thanks dude. and thanks mod's for editing title.
-__-
Sep 16, 2010 05:14 PM
98coupe#2
Mar 24, 2010 01:01 PM
le0ftw
Dec 24, 2006 06:13 PM
whookidb18c
Jun 8, 2006 06:08 PM
bigblockEG
Mar 29, 2002 02:30 PM
