b16a3 with gsr tranny - Is this a good combo?
the gsr ratio keeps your RPM's lower on the freeway.. which in turn will save you a lil gas... b16 trans will be at a higher RPM on the freeway, at cruising speed... the b16 trans will keep making you think you have to shift again, even if your in 5th gear.. hahaha
B16 trannies are short. But they are short for a reason. The B16 has a small powerband. Its tranny is designed to keep the motor in its powerband between shifts. A GSR tranny will net you a little better MPG's but you will be sloewr.
^^^^ i also agree there.... it mostly comes down to preference. and whats best for you...ive had both trans and i prefer gsr over b16, and thats usually what i get..
