chipping p2e ecu?
whats up honda tech!!
im sick of having terrible gas mileage in my d16y7, i'd like to chip and tune this bastard but the downside is i gots obd2, can i get the conversion harness to obdI and tune it on chrome? if anyone can just throw me a list of steps on this process it would be greatly apreciated. thanks honda-tech cheers
try sea foaming the car if you do it right youll have better gas milage but if you want to tune your car so bad get the step down harness p06 ecu get it chipped pick what you wanna tune it on get it tuned
yeah you need to get a p06 ecu that is non-vtec for your engine, chip and tune it, but if you want go good on gas millage, swich air filter, check tire pressure, put gas on the morning only and try to not run it to much just changing up speed like at 3000rmp
thanks guys, i got the info its all good, im going obd1 ecu chipping and getting the conversion harness from obd2 to obd1 and getting wideband. plus the gas millage is bad cause the car is at over 200k miles, idles at 1500rpm, so its deff phuckin tune time. thanks again guys.
+1
+1
