e.l.d. code 20
Old Sep 15, 2010 | 01:46 PM
mhewitt's Avatar
Default e.l.d. code 20
i was on the throttle and when i shifted to second the car just shut down, it turns over but is getting no fire and is throwing code 20. thats electronic load detector, i replaced under hood fuse box with known working one, ran the voltmeter tests like stated in haynes manual and everything checked good but still throwing code 20. i changed out the dizzy too just to see and it didnt help either checked fuses under dash n they r good too. any other suggestions?
Old Sep 15, 2010 | 05:21 PM
mhewitt's Avatar
Default Re: e.l.d. code 20
Bump for help
Old Sep 15, 2010 | 08:39 PM
bakomack's Avatar
change out underdash fuse panel, had the same problem with my rhd eg.
replaced under dash fuse panel fixed my problem
Old Sep 16, 2010 | 10:03 AM
speedoptions.ca's Avatar
Code 20 shouldnt be affecting your drivability. The ELD just detects electrical load and ramps up your alternator voltage to compensate. You should still be getting spark.
usdm_ED7
Aug 30, 2011 09:30 AM
tubed-ef
Oct 18, 2008 08:22 AM
digital sol
May 19, 2006 07:50 AM
cjames235
Dec 27, 2003 06:17 AM
Gennady
Jan 28, 2002 11:32 AM
