stock b16a 1/4 mile theory...thought this would be fun
Old Sep 15, 2010 | 08:39 AM
cehcivic15's Avatar
Default stock b16a 1/4 mile theory...thought this would be fun
wanted to start a thread about building a car strictly for the track. completely stock b16a motor. how fast could you get the car and what would you do to it. im talking down to the nitty gritty of grinding off dohc of the valve cover for weight reduction...lol. i was thinking dropping this motor in a crx. changing the gearing in the transmission and the final drive. gutting the car absolutley everything you will not need. removing sound deadner tar. going through the wiring harness and removing every wire you wont need. removing a headlight and running a velocity stack. running 2.5 exhaust maybe out the side of the car. maybe use 15" konig heliums, replacing the glass with lexan. even going as far as taking a hole saw and randomly putting holes in the floor pan for weight reduction. ecu tune...
im not doing this....i just thought it would be fun to hear some ideas on making a fast car with a 100% bone stock b16a and seeing what ppl thought they might get the car to run in the 1/4 mile
Old Sep 15, 2010 | 09:16 AM
unusual71's Avatar
Default Re: stock b16a 1/4 mile theory...thought this would be fun
too many variables but with the right prep Im sure 13's would be possible
Old Sep 15, 2010 | 10:08 AM
newtron63h's Avatar
yeah starting with a crx hx, extreme weight reduction might drop 200 pounds(aside from replacing essential parts with lighter weight parts). so you are looking at about a 1500lb car plus driver weight. id say also that the weight reduction should be limited to the back axle, otherwise managing wheel spin might make full throttle impossible. the lsd is going to add a few pounds but it will be in the right place too(at the front and low), but lower gearing might negate itself(better acceleration, but more wheel spin)
the biggest hurdle to overcome is having a driver that will launch it right, and manage wheel spin efficiently. all things being perfect id say low 13s would be possible. ive got a calculator that says with 160hp and 1675(1500ish pound car plus 175lbs of driver) gives a 1/4 time of 13.39@100.5.
now if you really want to get serious with it.......12s MIGHT be possible. but for that im talking about testing wheel bearings, alternators, water pumps and finding ones that have the least friction. also there are some things you can do to the engine which would keep it technically stock but might reduce frictional losses. so things like line-honing the mains, checking out the cylinder bores to make sure they are exactly perpendicular to the mains, match-fitting bearings, using the low end of clearance specs on ring gaps, line-honing cam bores, etc might get just a lil more power to the ground
so lets say you pick up "10hp" from reducing various frictional losses around the car, according to my calculator, that drops your ET from 13.39@100.5 down to 13.13@102.6
Old Sep 15, 2010 | 10:16 AM
cehcivic15's Avatar
awsome..i think it would be so much fun to build this car. you could put launch control on it to help out, some slicks in the front and maybe some traction bars. have a drag coilover kit on it. what else could help with wheel spin? keeping the battery up front and removing the fuel tank and putting a fuel cell under the hood adding some weight?
you could even remove the alternator....if its a drag only car
or maybe even remove the front disc brakes lol..
Old Sep 15, 2010 | 10:37 AM
newtron63h's Avatar
ummmmmm removing rear calipers and lines and plugging the lines at the MC, machine the front rotors to the minimum useable thickness, and machine all of the friction surface of the rear rotors off, then balance them. skinny and lightweight wheels and tires on the rear. fab a small fuel cell and move it forward in the car.
just some ideas
Old Sep 15, 2010 | 10:40 AM
newtron63h's Avatar
im not sure about a fuel cell in the engine bay......idk if thats allowed. but if it is, id say go for it.
Old Sep 15, 2010 | 10:41 AM
newtron63h's Avatar
could remove the alternator.....makes things a bit of a pain in the *** though. always gotta gave a charger on hand.
Old Sep 15, 2010 | 10:51 AM
dc2_dude's Avatar
how about a stock h22 in a dc integra??? i know its not a b16a but im looking to see how fast i can get my dc down the track without building the motor and cutting my car up!
run a intake 2 the front bumper.js racing intake duct (jdm front) bigger header. already have light weight wheels. gut the back half interior. the tranny is already geared low, running drag radials up front, rear bumper has 2.5in. holes cut out in it.
so 187hp 158tq 2500 lbs car...what do you think that would run??
Old Sep 15, 2010 | 10:59 AM
newtron63h's Avatar
my calculator is saying 14.53@92.6
Old Sep 18, 2010 | 09:37 AM
bambam's Avatar
These theoretical 1/4 times are pointless.
Old Sep 18, 2010 | 03:27 PM
newtron63h's Avatar
well, maybe they are, maybe they arent.........the great thing for you is that you dont have to participate if you dont want to.
Old Sep 18, 2010 | 03:37 PM
raverx3m's Avatar
plastic valve cover and intake manifold like on the new hondas.
would be nice if we could have that for b series.
high output alternator.
you could possibly build a much better motor with using higher grade metals so you can cut down on the thickness. like aircraft quality.
but that is stupid expensive...
these are production cars so thay are made to be a compromise between quality and price.
if would probably cost you alot more to get stock B16 to type-r numbers than just buying a type-r motor to start off...
Old Sep 19, 2010 | 10:35 PM
FURACERMAN's Avatar
There was a guy here running 12.8s with a stock internal B16, some kind of ecu with a raised rev limit, DC race header, 24" slicks, a welded diff, and a clutch. That was in a eg, with a driver seat, gauges, and full glass.
Old Sep 19, 2010 | 11:51 PM
H2b-eghatch's Avatar
think last month hondatuning was worlds badest CRX with b16 weight in at 16 0r 1700lbs.........
zex_cool
May 14, 2008 05:51 AM
MeatballHB
10
Jan 18, 2006 10:56 AM
bluedevil
Nov 25, 2003 10:53 AM
onefastcx
Jan 13, 2003 10:25 AM
Jaysmy
May 3, 2001 07:04 AM
