Parking Brake Light Coming On 1st-4th gear!
Hey,
My friend who owns a '99 GSR told me about his parking brake light coming on during hard acceleration in 1st gear. Now, He says it happens through 4th gear. I was thinking that a sensor wire is loose/disconnected or his parking brake cable needs to be adjusted. What would be the best route to fix this problem. No other symptoms as far as I know.
Thanks
Thanks
look for the brake switch...take out the center console? i dunno where its at
yeah find the switch, if the switch is cool trace that wire(s)
I understood Chiovnidca's reply... maybe not "top off" but make sure that the master cylinder has a sufficient amount of fluid in there...
also consider the amount of play the e-brake handle handle has... if the handle is sloppy it will also illluminate the brake lamp when hitting bumps and what not...
only 2 switches that will illuminate the brake lamp... E-Brake switch and master cylinder fluid level switch....
djw
Jul 27, 2010 08:19 AM
I will check those things today on his car.
