tranny rebuild questions
hi im rebuilding my transmission and have three questions right now. in the first pic there is a snap ring between the cv shaft seal and the differental bearing should this be there. in the second pic you can see where i cleaned a spot the whole trans is covered in it and you can see the where the oil level was is this normal or is it metal shavings and i will need new gears. in the third pic you can see that the reverse gear is all messed up can i just replace this or will the gears on the counter shaft and input shaft need to be changed also. sorry to dump so much in here and thanks for the help
Reverse idler gear looks fine, reverse isn't syncronized so a new gear is going to look like that after you use reverse a few times, its also the only gear where you actually shift gears, for all other gears you just move sleeves/sliders.
thanks it is a black film that wipes off so all good there. so the reverse idler doesnt look bad they will all get messed up. and last if i buy syncro set do the springs come with them.
i was looking at the syncros and they dont look rounded without taking it apart can anyone tell me if they look ok. and the reverse gear its self looks bad do i need to replace it or will i not be able to tell the diff the last two pics are of the reverse gear. thanks so much for the help. also let me know if i need to post in the tranny section for better response.
syncros look ok as far as the teeth and springs go, but whats important is the clearance between the syncro and the gear, the syncros have little pads on the inside to slow down the gears, if the pads are worn down the syncro bottoms out and doesn't slow the gear down. Also some of the pics are really blurry, I can't tell for sure but third looks like the engagement teeth might be worn. Everything really should come apart so you can check the condition of the sleeves. Reverse is pretty chewed up, i've never seen one that bad before, i'd probably replace it. note that its also the 1st/2nd sleeve.
you can take it apart by driving the input shaft against a block of hardwood, remove the nut on the countershaft and do that same for it. You don't need a torch for anything.
i just called that place and he said that the trans do not interchange so just to double check i can use the 96 tranny on a 94 dx sedan i was told on here that they do before i spend money on parts i wanna make sure i can use this tranny. the cvshafts match the bell housings and IS are the same lengh and i dont need to do anything but unbolt one and bolt the next one in thanks guys
'92 - '95 transmissions and '96 - '00 transmissions are completely interchangeable as a unit (automatics are another story) Even most of the internal components are interchangeable.
ok cool i was 98% sure that they would just the guy threw me for a loop.
ill be looking for the reverse gear and other internals any one have some that are good but used thanks
blowncivichb
Mar 20, 2002 02:25 PM
