D16 Overheats Uphills
Hello
I have a 92 civic with a D16Z6 turbo,DSM 450's,log manifold,turbonetics WG,Mishimoto thermostat,Mishimoto fan switch, New Oem water pump,Cometic HG,ARP head studs,trying to make as clear as possible the car runs fine its my DD drive to Los Angeles from Bishop some times runs fine but when i start going up steep hills it will overheat dont know why i replaced both the sensors temp sending unit and the the temp switch did a block test and ido not have a blown HG it only happens uphill i can race the car and it dosent happen also drive it everyday and it wont overheat its driving me crazy. If any one can halp PLEASE Thanks
Mine did the same thing a while back. It ended up being air in the lines. After it overheated, I just unscrewed the radiator cap and let the air out. Then filled it back up with coolant. Been fine ever since.
there should be a bleeder on the back of your housing that you can bleed the system from. when i get to my garage tonight i will snap a picture for you. sounds like tht is the issue considering you have tried everything else
E38Mk1
Jul 17, 2012 03:43 PM
jdm 1080p
Dec 7, 2011 12:18 PM
hotcivicsi
11
Apr 9, 2009 06:19 PM
