Intake and Exhaust B20v
Old Sep 14, 2010 | 06:12 PM
gutted-dx's Avatar
Default Intake and Exhaust B20v
I'm looking into finally getting my car tuned on the dyno, and I was curious if
I should change the Intake Manifold and Exhaust (catback). Its a daily driver but I'm still looking to get the most out of my setup.
Head:
P72
ITR Valvesprings
CTR Cams
PX Inatake manifold
68mm TB
3in. SRI w/Blox V-stack and filter
Block:
Stock B20z
Exhaust:
Hytech replica header
HKS Hipower
NO catalytic converter
The exhaust I was looking at is a VRS 2.5 piping, and possible the VictorX Intake manifold.
Thanks for the response,
Joe
Old Sep 14, 2010 | 06:18 PM
dntnedvtec's Avatar
Default Re: Intake and Exhaust B20v
I say tune it with what you have. I also hear that the performer X IM is a good IM for NA, while the Victor X is more suited for turbo applications. On the stock B20z block, I would be careful not to rev the **** out of it with out help. There is a reason why the B20's and the LS blocks aren't meant to rev high due to the bigger stroke an weak rod bolts. just my 2 cents...
Old Sep 15, 2010 | 08:38 AM
gutted-dx's Avatar
Yeah I know about the whole rod bolt deal its within the 200rpms of the sock limit. I've heard that the VictorX is better suited for 2.0s than the PX is.
Old Sep 16, 2010 | 03:02 PM
gutted-dx's Avatar
No input on the Intake Manifold?
Old Sep 16, 2010 | 03:10 PM
neverstop's Avatar
I would leave it man, no need to blow your motor up
Old Sep 16, 2010 | 03:33 PM
gutted-dx's Avatar
So putting a bigger exhaust and different IM on is goin to blow my motor up? haha
Anyone else?
Old Sep 17, 2010 | 07:51 AM
NA_B_FTW's Avatar
I think you should stick with the performer x (get it ported if possible) or maybe get the skunk2 pro manifold and do an intake manifold test between the two for us when you get it dynoed. The victor x is better for 2.0's than 1.8's, but you will still lose significant low and midrange power compared to the performer x. Since you're staying within 200 rpms of the stock rev limit (which is a good idea), you wont be revving high enough to really even gain any power up top from the victor x. You also mentioned it's your daily driver so most of the time I would assume you aren't revving to 7k+ rpms and you mostly stay in the low to mid rpm range so I think you would be much happier with the performer x. That's just my opinion though.
Also, if you don't mind the noise I would look into getting a 3" exhaust.
Old Sep 18, 2010 | 08:13 AM
gutted-dx's Avatar
The reason I originally got it is because it was made for that power band. I guess I'll upgrade the exhaust and then hit the dyno.
Old Sep 26, 2010 | 07:41 PM
gutted-dx's Avatar
Ordered my piping from VRS for $160 shipped.
Old Sep 26, 2010 | 07:45 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
skunk manifold .. i ran the itr IM on my 2.0 and it was perfect.
1.5boosted
Jan 20, 2008 06:33 AM
jmm611
May 9, 2006 12:39 PM
AussieK24
Feb 12, 2003 06:06 AM
Suprdave
Jul 9, 2001 12:53 PM
