***HELP!!!*** 98 Civic D16Y8 SWAP...WONT RUN...starts for a second then DIES..WTF
Swapped in a low mileage d16y8 into a clean 98 EX shell...Using a y7 harness...
im running a p06 via the jumper, does anyone know if this makes a difference??? i dont care about not having vtec i just want the car to run.
the car will die as soon as you give it gas, its throwing a code 14 and a code 10?
what do i need to do to get this car running
im running a p06 with a jumper obviously, i havent checked cel codes, do i have to get an autozone scanner for that?
un hook it from the manifold and clean it, see it that will take care of the problem. Also check the wiring that you added.
the motor was running perfect in my friends car last week so i doubt cleaning it will change any thing...code 14...code 10...
Lou845
Jul 11, 2012 02:53 PM
