1999 Acura Integra GSR Part-out (Tan Int. Cypress Green Ext.)
For sale
1999 Acura Integra GSR Interior and body parts
Interior:
Dashboard with harness and airbag $135
Both Airbags and SRS unit and Harness $120
Center Console Front Half Only - $35
A-Pillars $20
B-Pillars $20
Trunk Plastics $25
Glove Box $45
Steering Column Plastics $30
Dome Light $10
Map Light $10
Clock $15
Exterior: (Cypress Green)
Passenger Side Door (no window motor) $100
Front Core Support(including Front half of inner fenders) $115
Front Bumper support $45
Rear Bumper Support $45
Rear Bumper Older style Flat Bottom (Missing some paint, no deep scratches, holes etc...) $45
Spoiler (Passenger side mounting bolts are detached, still have them. OEM Honda) - $30
Harness UNCUT
Body harnesses that go inside along the floor on both sides of the seats, goes to the back across where the taillights are and the one that goes up into the hatch to feed the rear wiper and defroster. also have defroster ground wire $80
I do not have the engine harness
Under the hood:
1994 Acura Integra GSR Swap 100% complete.
Engine was pulled from a running car, saw and heard it run, didnt smoke, tap, knock, overheat. Did a compression test and it was within 6% of 220 across the board.
Comes with the complete engine longblock, transmission, motor mounts, shift linkage, axles(has torn cv boot) wiring harness, ecu. $2500
Radiator Fan $25
Condenser Fan $25
Air conditioning Condenser $35
Power Steering pump $40
Power Steering Rack $110
Clutch Master Cylinder and Reservoir $65
ABS Brain and Distribution cylinder $50
A/C Lines (From condesnsor to evaporator and back) - $55
Battery Tray and Holddown - $20
Clutch Line (From master cylinder to slave cylinder) - $20
Windshield Washer Reservoir and pumps - $20
ABS Proportioning Valve - $15
Cruise Control unit and cable - $40
Front Wiper Arms - $20
Rear Wiper arm and motor - $40
Front Subframe - $100
Pedal Assembly(Gas, Brake, Clutch) - $65
Windshild wiper motor $35
Cowl $25
Fuse box(underhood) $20
Gas Tank(with sending unit and fuel pump)and straps $85
Gas tank filler neck and cap $25
Sunroof motor and glass(complete unit) $120
Headliner(small hole) $25
If you dont see something small listed then ask i might have it, as for bigger parts i'll list at the bottom what is gone. thanks for looking!
If you need pictures or have questions email me at napster56754@aol.com and include in the subject your from hondatech about the integra.
I will respond to pm's however i do not know how to send pictures through them.
Please bump if you look!
Interior:
A-Pillars $20
B-Pillars $20
Trunk Plastics $25
Glove Box $45
Dome Light $10
Map Light $10
Clock $15
Harness UNCUT
Under the hood:
Radiator Fan $25
Condenser Fan $25
Cowl $25
no sorry they are gone. I do have a drivers side integra cloth seat if you'd be interested in that. its a darker color, i believe its a dark grey.
