raise CR in b18b
Old Sep 18, 2002 | 03:05 PM
DOHC-DX's Avatar
Default raise CR in b18b
i'd like to bump up the CR in my b18b. i have mild cams, i/h/e, MSD, walbro pump.
what can i safely raise the CR to with stock b18b head/internals?
are there any OEM pistons can i install to bump CR in a b18b? USDM b18c5? or, is there not enough head clearance?
Old Sep 18, 2002 | 03:40 PM
DOHC-DX's Avatar
Default Re: raise CR in b18b (DOHC-DX)
anyone?
Old Sep 19, 2002 | 06:37 AM
Civic DX 4dr's Avatar
I'd go with either p30 or ctr pistons. If you have some lying around, go with the pr3. Either choice would be fine. The pr3 being the lowest of the three and ctr being the highest.
Old Sep 19, 2002 | 06:51 AM
EKhatch's Avatar
Default Re: raise CR in b18b (Civic DX 4dr)
# 10 in the link has your answer.
http://www.geocities.com/teampimports/lsvtec.html
Old Sep 19, 2002 | 07:15 AM
DOHC-DX's Avatar
Default Re: raise CR in b18b (EKhatch)
according to the CR calculator on c-speedracing.com, the pr3 in the LS block/head will result in 10.8:1 CR. that's what i'm leaning more toward now because the pr3 are USDM, and can be had more easily.
also, is it true that I will need to have the pin holes on the rods machined a bit so the pr3 pins will fit?
i plan to use:
ARP rod bolts
pr3 pistons std bore
new pr3 rings & pins
OEM LS 3layer head gasket
shotpeen the rods
balance everything
hone the walls
i'm planning to use the stock 240cc injectors, any thoughts on that? i've heard of others using the stock injectors with LSVtec and 11.5:1 safely. i have walbro 255lph fuel pump, B&m fpr & fpg.
[Modified by DOHC-DX, 6:46 PM 9/19/2002]
Old Sep 19, 2002 | 08:27 AM
lsturbo's Avatar
i got CTR Pistons on my ALLMotor LS.. NON-VTEC
berts95ej
Sep 17, 2007 08:54 PM
The Stance
May 25, 2005 03:12 PM
VTEC-DA
Jan 4, 2003 09:48 AM
dlric
Feb 13, 2002 09:00 AM
mamaboy
Jan 12, 2002 12:56 PM
