HELP!! '93 Delsol Smoking + Burning Oil
Old Sep 13, 2010 | 05:37 PM
CadillacDelSlo's Avatar
Default HELP!! '93 Delsol Smoking + Burning Oil
I recently purchased a 1993 Honda Civic Del Sol with the 1.5 SOHC Engine with 201xxx. Good condition over all. All stock. One major problem I knew about when I bought it is needed a Half Shaft(successfully done) and Burning oil. She has a new head it appears and has reamnence of coolant splashing the hood. I am assuming this is why there is a new head. She is fouling the plugs and is burning a quart of oil every 100 miles and is smoking perfucely(fills an intersection). There is no coolant in the oil, no oil in the coolant, and has a new head. I only know what have have figured out by myself as I bought it from a lot and you could only trust the guys as far as you could see them. Please Help!! I believe everything points to the rings and That's what she needs along with some Love. For more info Just ask. I bought it for MPG's....And cuz its a Honda and FUN!!! But I cant afford 4$ in oil every 3 to 4 days.
Thanks for looking and any help. Oh and A walk through of doing rings would be awesome Ive looking high and low for three days now.
Old Sep 13, 2010 | 05:48 PM
em1pusha99's Avatar
Default Re: HELP!! '93 Delsol Smoking + Burning Oil
don't even bother with just doing rings, at least swap in a D16Z6. Overall cheaper, unless you go "redneck" and just put in rings. Sounds like the engines been through hell anyways no sense in trying to save it. Just swap it, you'll be a lot happier in the long run.
Old Sep 13, 2010 | 05:56 PM
Okay well since the head is new I figured I'd assess the situation once I got In there and It's Just a beater so it the walls where scraped then i was going to replace them. That means only thing that is original is pistons and rods and the crank. So Now that I think I guess you 'd call it RedNeck but Do you think that its the Rings? Provided the walls are good and a new head?
Old Sep 13, 2010 | 06:04 PM
vitamin_c95's Avatar
could be rings valve seals or both. try doing a compression test.
Old Sep 14, 2010 | 12:15 PM
I am working on getting a compression tester today so hopefully I'll know. But everything points to rings. I'll let you know and we'll go from there. Thank you for everything so far guys.
EG6_LS_BOOST
Mar 18, 2014 05:49 AM
1701j
Honda Civic (2001 - 2005)
Apr 5, 2009 06:32 AM
wm5holla
May 19, 2003 07:30 PM
93LSivic
May 27, 2002 10:27 PM
itr980923
Mar 17, 2002 05:27 PM
