My car shuts off by itself i need help
Old Sep 13, 2010 | 05:26 PM
JEEZY SI KID's Avatar
Default My car shuts off by itself i need help
i drive a civic si and my car shuts off when i turn it on but if i crank it again it turns on and sometimes while driving it or leaving it on it shuts off by itself what can it be i checked spark plugs for flooding n their good wat can it be i need help???
Old Sep 13, 2010 | 05:29 PM
Former User's Avatar
Default Re: My car shuts off by itself i need help
Any CEL codes? A bad ICM inside the distributor is a common cause of stalling. You may want an auto parts store to test it, and the coil.
Also inspect the spark plugs, wires, cap, and rotor.
Old Sep 14, 2010 | 06:53 PM
I checked the spark plugs their good no code just throwing idle air control valve but i got that fixed ...someone told me might be the distributor can it be the whole piece or just the cap and rotor???or coil
Old Dec 13, 2011 | 05:52 AM
skhanal2's Avatar
Exactly the same problem with my civic ex....what was wrong with yours??
Old Dec 13, 2011 | 06:33 AM
Blacknight117's Avatar
If the car starts then turns off, than it`s more than likely the dizzy. Check it. Check the rotor, cap, coil, and than the distributor itself for any cracks.
Old Dec 13, 2011 | 09:43 AM
loveek's Avatar
I had same problem with my car and the guy told me to change my head gasket n it worked I hope it help you
Old Dec 13, 2011 | 03:34 PM
I have never in my life ever hear that a headgasket would cause the car to shut off...OP, check the distributor...
Old Dec 15, 2011 | 01:28 PM
skhanal2's Avatar
Turns out that my crankshaft sensor was not working.
teamTakeo
Aug 20, 2023 07:58 PM
sr20paisa
18
Jun 10, 2016 05:35 PM
gizmo jdm
Nov 14, 2011 04:29 AM
homer_eps
12
Apr 9, 2008 08:09 PM
BadBeck
Dec 11, 2003 05:59 PM
