What is a cheap descent but reliable setup?
Like the tittle says, I was thinking about boosting a 97 Gsr motor but was wondering what to get or how I should get started Im only looking to make 350 hp. opinons and suggestions or anything would be useful
if you have e85 around your way it can be reliable..or a really good tuner...but cheap and reliable dont mix...i learned the hard way...the cheapest way is to source quality used parts and turbos...use tial wastegate and bov...garrett turbo...dont buy ebay brands...i was running 11psi on a 60-1 made close to 300 tuned conservatively because it had alot of miles...and i still cracked a sleeved...im think bad pump gas i had just refueled the day before...
Source out parts from the classifieds and it can be done easy. I'm at 360 on a stock gsr. And I got all good reliable parts. Just take ur time and do a lot of research on pricing and stuff. Good luck
thanks guys I think im gonna go for a realiable setup, I rather spend a good amount once then having to keep spending money on some cheap parts over n over again. Its not like I'm in a rush winters coming up perfect time for me to sit back and do some research and put a decent reliable turbo kit together, once again thanks guys that helped
