Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
what sway bars do you guys recommend?
Old Sep 18, 2002 | 02:33 PM
Mike D's Avatar
Default what sway bars do you guys recommend?
This is for a 92 hatch with gc/konis already. Rates are 350f/400r. So which do you guys recommend?
I know a popular one is the type r, but how do ST or other brands compare?
Thanks for the help.
Mike D
Old Sep 19, 2002 | 11:21 AM
Doctor CorteZ's Avatar
Default Re: what sway bars do you guys recommend? (Mike D)
ITR rear bar
stock front
for the money its a great combo..........
Old Sep 19, 2002 | 12:05 PM
Mike D's Avatar
Default Re: what sway bars do you guys recommend? (Doctor CorteZ)
where does everyone buy there ITR rear bar? Just keep an eye out for them?
Thanks for the help doctor
Mike D
Old Sep 19, 2002 | 12:06 PM
StageOne's Avatar
Acura Dealer
Old Sep 19, 2002 | 12:54 PM
Default Re: what sway bars do you guys recommend? (StageOne)
backorder last time I checked
dont forget a GODD reinforcement kit
Old Sep 19, 2002 | 12:55 PM
navin's Avatar
he has no front bar Dr.Cortez. Some one reccomend a good front bar for him, I am personally gonna use the GSR/ITR 24mm Front and Type-R 22mm Rear.
Old Sep 19, 2002 | 12:58 PM
Default Re: what sway bars do you guys recommend? (navin)
he didnt say what model hatch , I said "stock front" meaning stock civic bar
I dont like the 24mm front bar , it induces understeer IMHO
22mm front bar - NO bigger.
Old Sep 19, 2002 | 01:03 PM
navin's Avatar
Yah I want to test it out at VIR - maybe when funds are availble. For now its just trial and error I guess...
Old Sep 19, 2002 | 01:06 PM
civic bar = cheap
35 beans used.
Old Sep 19, 2002 | 01:11 PM
siisgood00's Avatar
New User
Cant say enough about my Comptech 22 mil rear sway/tie combo.
Old Sep 20, 2002 | 01:13 AM
Viorent GRIP!'s Avatar
If you can't find a stock ITR one, you can always go with a Skunk2 rear sway. Same thing as ITR. Love mine with the Beaks kit.
Old Sep 20, 2002 | 03:31 PM
Mike D's Avatar
Default Re: what sway bars do you guys recommend? (Mr. Shin)
I have a dx. do they make a mugen 26mm for my car? havent looked, but mated with a gsr front, should make a good combo?
Thanks....Mike
Old Sep 20, 2002 | 04:19 PM
jc836's Avatar
Take your choice. I am using Neuspeed on the rear of the Prelude, ST on the Civic HB (F&R) and ADDCO on the CRX rear. Given a choice and best bang for my $$$ I would look at ADDCO (available direct or from Summit) or Neuspeed (even if they are more $$$). The ST bars are generally used in sets BTW.
Old Sep 20, 2002 | 04:23 PM
carl_aka_carlos's Avatar
well, my set-up is slightly stiffer than yours, but I run ST bars front and rear (25mm front, 19mm rear ) with konis and GC's 450#/500# springs. works exceptionally well. course, if you've never driven an oversteering car you may not like it, I moved to my integra after 3 years running a 99 Cobra in ESP, so having a car that tends to oversteer is what I'm used to/comfortable with.
Old Sep 20, 2002 | 05:33 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i run a stock civic front bar (21mm???) with a mugen 26mm rear bar. nice........
Old Sep 20, 2002 | 06:52 PM
JaeOne3345's Avatar
Default Re: what sway bars do you guys recommend? (rodney)
ST front and rear for about 245 from summit. works great.
Old Jul 6, 2003 | 02:29 PM
Patron's Avatar
can someone oversimplify these options?
Large front bar & Large rear bar = ?
Large front bar and Small rear bar = ?
Small front bar and Large rear bar = ?
Small front bar and Small rear bar = ?
which would you recommend for Ground control coilover w/ stock shocks on a civic hatch?
Old Jul 6, 2003 | 02:39 PM
Patron's Avatar
Default Re: what sway bars do you guys recommend? (ptran13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptran13 &raquo;</TD></TR><TR><TD CLASS="quote">can someone oversimplify these options, and the effects of getting these particular setups?
just front = ?
just rear = ?
which would you recommend for Ground control coilover w/ stock shocks on a civic hatch?</TD></TR></TABLE>
Old Jul 6, 2003 | 02:52 PM
Mike D's Avatar
wow, back from the dead....
Now im answering this from a hypothetical stand point. The spring rates, shock setting, tire pressures, etc, can greatly change how the car handles, regardless of the sway bars.
Large front bar & Large rear bar = more neutral
Large front bar and Small rear bar = might tend to understeer
Small front bar and Large rear bar = probably tend to oversteer
Small front bar and Small rear bar = again, probably more neutral
just front = understeer more
just rear = oversteer more
Again, this depends on how your car is set up, and can vary greatly from set-up to set-up. But for the most part, thats how those combos should effect the cars handling.
Mike
Old Jul 6, 2003 | 03:22 PM
Patron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike D &raquo;</TD></TR><TR><TD CLASS="quote">wow, back from the dead....
Mike
thanks for the fast response, yea i didn't feel like being torn into for asking a question that was already asked so i brought one back from the archives.
today when i went auto-xing for the first time, i understeered quite a bit, it may have been because of 1) driving experience 2) mediocre front tires, but i was hoping a sway bar set-up could also help. so would you recommend, possibly equal front and rears or just a rear to reduce understeer?
Old Jul 6, 2003 | 03:57 PM
Vitt1's Avatar
Get the ITR bar at a discount retailer like http://www.ahmotor.com, it'll cost a lot less than the dealer.
I thought the Skunk2 was 21mm vs. the ITR 22mm unless they changed it again.
fluke83
Jul 8, 2004 10:05 PM
Mike36
Nov 5, 2003 08:36 AM
stnwag0n
Oct 24, 2002 06:34 PM
animated_life
Sep 27, 2002 03:10 PM
Nighthawk GS-R
Apr 30, 2002 03:21 PM
