Rebuilt D16Y8 has an intake air leak between the IM about head
I just put a rebuilt y8 in my 00 civic and the head that came out has markings p2j-2 00 and the head that's on the new motor has p2j-2 96 and now my idle is at 2k and sucking air in between im and head.. if anyone could help please let me know how to fix .... thanks
An informative thread title is required and helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
Sounds like a problem with the FIA system. Read this thread:
http://www.hondacivicforum.com/forum...ad.php?t=40476
Is it sucking air directly between the IM and head? Like where the gasket would be? Because 96-98 IM have different air properties than 99-00 IM's. So, you may have leaking spots that wouldn't show up on a 99-00 Y8.
Yes its sucking air right where the basket is if you spray injector cleaner it bogs the engine down I reused the gasket from my old head . Can this be fixed with a gasket ? Or what are my options
if the old gasket isnt a hondata or similar gasket it is single use only. that is part of your problem. fel pro and similar gaskets cannot be used more than once.
I think it was a factory gasket... are the gasket for a 96 n 00 the same if not which gasket will I need
im not 100% sure if they are the same or not, but call your local auto parts store and see if the part numbers are the same. my guess would be to go with whatever head/intake mani you have regardless of year. changing the IM gasket is about a 30-45 minute job, maybe an hr or so first time.
Well called local parts store and gasket for 96 n 00 are different so im stumped on which one to use any suggestions
the 2000 Y8 manifold has injector air bypass, the 96-98 doesn't. you can either swap your manifold for one without the bypass (pre-'99) or remove your '00 manifold, tap the holes and plug them will set screws (RTV sealant or thread lock on the threads).
the tell-tale sign of a 99-00 with the injector air bypass is the small hose barb in the center of the manifold->head flange.
That's what I was trying to say:
So me changing the gasket is not going to fix this because it seems like the gasket is not sealed since its sucking in air across the top part of head ?
Onimuno
Feb 6, 2014 09:27 AM
jacekattack
Jan 15, 2012 05:18 PM
JokerX-1.6T
Apr 5, 2007 11:48 AM
jkiddSI
Aug 7, 2005 08:44 AM
