BC crower stg. 2 NA cams?
Old Sep 12, 2010 | 09:31 PM
hYbRid_Eg6's Avatar
Default BC crower stg. 2 NA cams?
ok I wanted to pick up a used greddy kit here locally and boost 6-8psi, my current motor is stock gsr with flat valves, ti ret., dual valve springs and bc stg. 2 NA cams, my question is what kind of problems will i run into with this set-up? too much overlap with cams? Im in the process of building a turbo motor but i cant wait i just want to feel boost now!!
Old Sep 13, 2010 | 07:33 PM
hYbRid_Eg6's Avatar
Default Re: BC crower stg. 2 NA cams?
anyone?
Old Sep 13, 2010 | 07:39 PM
hYbRid_Eg6's Avatar
anyone?
Old Sep 15, 2010 | 08:14 PM
hYbRid_Eg6's Avatar
can i use these cams or not?
Old Sep 16, 2010 | 04:46 AM
kyden's Avatar
greddy kit? i wouldn't bother with cams bigger than ITRs.
Old Sep 16, 2010 | 01:43 PM
lsneo's Avatar
i use these cams on my ls turbo setup and they work great. Make power all the way past 8k.
Old Sep 16, 2010 | 06:00 PM
hYbRid_Eg6's Avatar
well I was just going to use for a lil until I get my other block built with gt3076r, so will these cams work then?
Old Sep 17, 2010 | 05:45 AM
kyden's Avatar
i wouldn't even use them for a 3076. 35r+
Old Sep 17, 2010 | 07:01 AM
unusual71's Avatar
agressive overlap will hurt power and spool
Old Sep 17, 2010 | 05:55 PM
mrbsponge's Avatar
NA cams work great on the LS. We use 404s in our LS at the shop and made 379 on a stock bottom end.
although I will warn you BC cams are starting to be more like BS cams! we refuse to even carry them or order them at our shop. the last set of valvesprings we tested had 3 more lbs of seat pressure than oem
Old Sep 18, 2010 | 09:52 PM
hYbRid_Eg6's Avatar
what aftermarket cams are good for the 3076? But why do I see or hear people running sk2 pro2 stg 1 cams, those cams are way more agressive then the stage 2 I got.
Jdm_Ej8_Sedan
Feb 25, 2014 05:04 PM
Japankid
Jul 24, 2009 07:12 PM
LaOstha
Aug 3, 2006 09:16 PM
thehatchninja
Jun 10, 2005 11:37 AM
JCracer723
Sep 8, 2002 06:07 PM
