D15B block, D16z6 head, will the z6 tranny bolt up?
Old Sep 11, 2010 | 04:04 PM
SpeedRacer420's Avatar
Default D15B block, D16z6 head, will the z6 tranny bolt up?
I need to know if a D15B block will bolt right up to a d16z6 tranny, thanx in advance for any help!
Old Sep 11, 2010 | 04:22 PM
kaiba's Avatar
Default Re: D15B block, D16z6 head, will the z6 tranny bolt up?
YES!
Old Sep 11, 2010 | 04:24 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Originally Posted by kaiba
YES!
Old Sep 11, 2010 | 06:34 PM
lil_chris_ejgsr's Avatar
Most d series parts are interchangeable and in my opinion the z6 tranny is way better in every aspect.
Old Sep 11, 2010 | 07:46 PM
HONDABOI666's Avatar
yes the z6 trans will bolt up with no problem at all. this will be one nasty mini me swap!
Old Sep 12, 2010 | 04:03 PM
Lol cool thanx guys, i did run into 1 problem that i have a solution for on the way already but i just thought i'd post it to possibly help someone else! The flywheel that was on the d15b block doesn't fit with the clutch i took of the d16z6. My plan is to just use the z6 flywheel waitin on an impact wrench to get them off kuz i can't get them myself. Should work though i'll let you guys know!
Old Sep 12, 2010 | 04:57 PM
cjw_89's Avatar
b fits b
d fits d (unless 01++)
f fits f/h
Tighten in one of your "bell housing bolts" so to speak and jam a pry bar onto the tooth of your flywheel, or get a 17 or 19 mm soccet,and a power bar and put it on your crank pulley and jam it on the floor and loosen and tighten them from there.
Ej1 honda
Jan 9, 2012 03:23 PM
93 Eg Couper
Jan 9, 2010 11:10 AM
JDMCRX
Oct 14, 2003 08:33 AM
KStuned
Sep 4, 2003 02:10 PM
