Lean Idle at startup idle.
Old Sep 11, 2010 | 03:45 PM
mouab18c1's Avatar
Icon2 Lean Idle at startup idle.
97 Acura Integra Gsr will have a lean idle after warm startups Afr reads around 16-17. At cold start ups it will idle at 14-15 AFR which IMO is still a little lean for a cold start up. It is said that a warm idle should be around 14.7 AFR Not when cold. Just looking for some inputs. My car is currently running on a Neptune RTP board with an lc-1 Innovate Wideband. Besides that everything is fine while crusing also the car will idle nicely in the 14 AFR range when warm. Any inputs are appreciated. Thanks in advance.
Old Sep 11, 2010 | 07:36 PM
mouab18c1's Avatar
Default Re: Lean Idle at startup idle.
No one? More tuning needed? If I remember right I had this problem when running on Crome as well
Old Sep 12, 2010 | 07:28 PM
mouab18c1's Avatar
Bumped up the fuel on Neptune. Hopefully it helps.
Old Sep 12, 2010 | 10:05 PM
jturbo8316's Avatar
ur best bet is to probably go and get it tuned
Old Sep 12, 2010 | 10:22 PM
mouab18c1's Avatar
It's street tuned
Old Sep 15, 2010 | 10:05 PM
mouab18c1's Avatar
Anyone?
ncsi
Feb 9, 2012 02:06 PM
mouab18c1
Engine Management and Tuning
Sep 18, 2010 05:06 PM
Hyaboosta
Jul 13, 2005 02:14 PM
SSS2000
May 11, 2004 04:21 PM
