Random 88-91 parts *Rear Disc-Header-misc* DA CF
Looking to meet up mostly but can ship.
More stuff will be added! So check back....
Parts I will trade for listed at bottom.
D Series 4-2-1 one-piece DC header: Ok shape, some corrosion and rust, needs to be repainted $50
will have picture shortly...
91 Civic STD driverside mirror(unpainted black) and Passenger Side Mirror BLock-off. $40 No pics at the moment, I just took them off my 91 civic std....
90-93 Integra (non-ABS) Password JDM Carbon Fiber Battery Holder/Relcator. $100
It uses an Odyssey 680 battery which is NOT included.
Here is a link to password jdm site- http://passwordjdm.com/PasswordJDM-B...P1901C457.aspx
DA Integra Guage Cluster (Manual trans) $20
It does have some scratches on the clear plastic but otherwise in good shape.
FS: ONE, ONLY ONE Front OmniPower 5-way adjustable Full Coilover for 88-91 Honda Civic/CRX $75 Street spring rate. Good for a back-up/replacement.
- 90-91 Honda Civic hatchback front bumpers. one unpainted and one red. The unpainted one has some scatches on the left side(shown in pic) and the red one has a messed up part on the left side also. $20 for the black one $10 for the red one
- '91 CRX Si Plastic Cowl Cover
- '91 CRX Si Lower Side Peices
- Resistor box (OBD1 green plug)
- 88-95 non-vtec D Series Valve Cover
- 90-91 CRX Rear fender trim peices
- '91 CRX Si Rear Swaybar
- 88-91 Speaker Cups
- Locking Lugs with Socket (couple of them have threads that need to be cleaned up) $15
- '91 CRX Si Rear Speaker Frames
- Intake Tube
- 88-91 CRX Fuel Door
- 89-91 Civic/CRX Crank Pulley with AC/PS
- 88-91 DX/STD DPFI Throttle Cable
I will trade for the 88-91 Civic Parts listed below:
-Stock Shifter with good bushing
-Lowering Springs and Shocks for 89-91 Civic/CRX
-2 peice header for d-series with o2 bung up top
-D-series cable Si trans or maybe a DX trans
-Decent 6.5in Speakers
-4 channel amp
-14 or 15in wheels(no steelies)
-Dark blue Sedan Doors, Hood, Front fenders, Front bumper and front filler(90-91 and non-rusted)
-Sedan Manual Seatbelt Conversion
-MPFI conversoin parts
- Intake Tube
-4 channel amp
if your rear lower control arms have the provisions for a stock rear sway bar then it will bolt up. it will be a threaded bolt hole on the lower control arm.
