Suspension & Brakes Theory, alignment, spring rates....
BuddyClub n+ squeak in rear..but....
Old Sep 10, 2010 | 10:35 PM
jdmej814's Avatar
Default BuddyClub n+ squeak in rear..but....
hey guys, ive extensively searched for this problem but cant seem to find a solution to my problem, so forgive if it sounds like a repeated question.
I'll make this sound as easy as possible.
Bought semi-used buddyclub n+ suspension for my dc2 recently
installed the suspension at my boys shop
noticed i had a squeak coming from my rear on the driver side
i ended up replacing the trailing arm bushing and others.
squeak still there
then i swapped the rears from left to right (driver to passenger)
now the squeak obviously is on the passenger (right) side
i emailed buddyclub, got a number, and called
they said check the preload. (sorry that i dont kno how to check)
or check top hat (which i already tried tightening, no luck)
he said shock is bad only if its leaking which mines not.
so help please, what should i check, thanx. i hope i took out a lot of possibilties because i did end up changing bushings, and werent it.
Old Sep 12, 2010 | 01:07 PM
STOCK_SOHC_DX's Avatar
Default Re: BuddyClub n+ squeak in rear..but....
try spraying the top hat with silicone spray.
Old Sep 17, 2010 | 01:11 AM
a97b18b's Avatar
I'm not sure what it is..could be the top hat, check the bushing or throw some grease on it.
To check the pre load it's the perch right under the spring. That's only suppose to be like hand tight I believe. I'm unsure how you're suppose to check it but I guess you could measure the height of both rear springs and make sure they are the same
Verkmiester
Mar 19, 2016 12:09 PM
jumal
Sep 21, 2011 05:24 PM
MRBOOMBASTIC
May 21, 2009 11:14 PM
playa192
Apr 22, 2009 07:22 AM
BigChris
May 10, 2004 10:22 AM
