Need help with my chronic car problem.
Old Sep 10, 2010 | 07:32 PM
Eclectia's Avatar
Default Need help with my chronic car problem.
Ok, this is a long story but i didnt want to leave any information out. i have a 1988 civic dx with a b18a1 swapped in, running obd0. The car has been throwing a code 43 for a long time. I replaced the oxygen sensor, but the code came back. A few days ago my car wouldn't start. The ecu was throwing a code 1 or ten( not sure) 15, and 43. I reset the ecu and it started up, but idled really rough, i gave it some gas and it seemed to run fine. i drove it too work, then on my way home it died while i was driving. I got it started and made it home. Only throwing the code 43 now. The next day i left for work and my car cut off while i was driving down the mountain, no other codes thrown, it started up again and on my way back home it work jerk really bad under acceleration. while i was going down the mountain, it lost all power, like it wasn't getting fuel or air. I couldn't accelrate going 45 downhill in fourth gear. I bogged down worse and worse and finally died. started right up in a few mintues and i took it home. I assumed my fuel filter was clogged and replaced it. When i took the car out for a test drive it was doing the same jerking, if i floor it it runs fine until 3000 rpm where it feels like the throttle slammed shut or something, this happen again in the higher rpms, then i noticed my tach dancing all around. I did some research on the forums, and concluded that my igniter was bad. I replaced it but the jerking is still the same, but i havent seen the tach doing the weird motions anymore. Any body have any idea what my problem might be?
Old Sep 11, 2010 | 09:38 PM
Eclectia's Avatar
Default Re: Need help with my chronic car problem.
I really need help with this one, I don't have any other transportation.
Old Sep 11, 2010 | 09:43 PM
megomaniac's Avatar
I guess i start with plugs and wires, checking and cleaning all grounds, thermostat ground,
check tps and map connectors secure
maybe take it to a shop,
Old Sep 11, 2010 | 10:49 PM
97ek-t's Avatar
how did they do the multi point wiring? maybe some wires are messed up
Old Sep 12, 2010 | 10:32 AM
Eclectia's Avatar
Can't take it to a shop, i live in a small town and the local import shop freaked out when they saw a civic with a b-series and refused to work on it. I"ll check plugs and wires, my grounds look good. anyway to check if your map or tps sensors are working right?
Old Sep 12, 2010 | 11:11 AM
Eclectia's Avatar
I don't think its the plugs and wires, since it runs fine below 3000 rpm. I don't know how they did the mpfi wiring, but it ran fine for months, just started doing this about a week ago.Anyone have anymore ideas?
Hybrid_DA
Sep 2, 2011 02:55 AM
2poor2tune
14
Nov 16, 2006 06:21 PM
juice91si
12
Oct 29, 2005 02:08 PM
CLICC916
Aug 8, 2002 10:35 AM
