Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
supercharger or turbo
Old Sep 10, 2010 | 05:32 PM
mase08's Avatar
Default supercharger or turbo
i have a 8th gen 6/6 accord and have been back and forth on weather to run a turbo or supercharger.. i know cost is a big difference on some.. i want to boost to just over 500 hp any thoughts
Old Sep 11, 2010 | 01:58 PM
accord99power's Avatar
Default Re: supercharger or turbo
research research research interested in seeing a link to a super charger for your vehicle
Old Sep 11, 2010 | 02:35 PM
MSchu's Avatar
My Name is Nobody
comptech currently(maybe discontinued now) had a super charger for the tl... the same set up as your 8th gen. price was something like 4k$... but really, when you do these types of modifications... price should be no object. In that case, run twin turbos with a motec management system. It might only set you back 10-15k$... maybe. But then you need to start thinking about putting in an LSD from the TL, and you need to start thinking about stopping the car after you have it up to 160+mph....
in the end, there is little a boat load a money can not fix.
Old Sep 11, 2010 | 03:06 PM
would supercharger put out 500 whp? i agree with turbo setup, but if he's asking the question i would say theres little research done here.
Old Sep 11, 2010 | 03:10 PM
MSchu's Avatar
My Name is Nobody
lol... not one from comptech
Old Sep 11, 2010 | 09:24 PM
ilikehonda's Avatar
turbo setup could be tricky. the exhaust manifold is cast into the head. but could also make it a little easier. the next step is tuning. What kind of tuning software is out there for these?
Old Sep 12, 2010 | 04:28 AM
LPED's Avatar
The problem I see is 500 hp is a lot , just about double the 08 V6 which is running 10.0 CR . Internals would need beefed up as you probably need around 15-20lb of boost . So some better forged rods along with some turbo forged pistons be in order (something in the 8.0 CR . You need larger injectors along with some kind of decent ECU.
Maybe 400hp could be done on stock internals but 500hp IMO is pushing it if you want it to last .
The exhaust manifolds shouldn't be problem, its going to be custom work as no kit are out that I know of . I think 2 small turbos would fit ok .
After you get it all done then have to get that power to the ground ,some LSD as mentioned above and a better clutch package too (hopefully the tranny will hold up if your not to hard on it ) .
Ponyboy
Acura NSX
31
Jan 14, 2013 12:26 PM
2point3h22lude
Jul 6, 2005 02:33 PM
sanitarium
Jun 24, 2005 07:33 PM
Acura_Kid
Mar 27, 2005 01:34 AM
hotaccord2
Feb 10, 2004 06:35 PM
