plastic bag started to melt on my exhaust right after the cat...
Old Sep 9, 2010 | 06:55 PM
PowerLeg's Avatar
Default plastic bag started to melt on my exhaust right after the cat...
what do i do? i can't stand smelling that burning/melting plastic bull ****
i feel like i'm going to get cancer from that ****
any ideas? cant even sscrape it off...
Old Sep 9, 2010 | 10:39 PM
cadeMFjohnson's Avatar
Default Re: plastic bag started to melt on my exhaust right after the cat...
spray the **** out of it with lots and lots of brake cleaner. carb cleaner will work too/better even.
Old Sep 9, 2010 | 10:41 PM
NOFX's Avatar
H-T White Ops
Never had it happen to me, but I found the following suggestions via Google:
- Wait and let it burn off on it's own.
- Scrape it off with a hard plastic putty knife.
- Burn it off (someone got Meineke to do it for them).
- Use spray oven cleaner (don't get it on anything besides the exhaust pipe! it's very corrosive.).
Old Sep 10, 2010 | 12:23 PM
PowerLeg's Avatar
its on my spec2... =(
maybe i should run open header in the mean time... i dont want to be breathing that plastic in and theres a good mess melted on there
probably bout the size of a cut open tennis ball and layed flat so theres a good amount of it.
damnit my bolts are semi seized this is going to take so much effort
how long does it take to burn off? god damnit
as for cleaners i have googone and a environment safe DEGREASER would those work? i also have a scruff pad but i'd like to not scratch the hell outta my exhaust if i dont nee dto
Old Sep 10, 2010 | 12:43 PM
NOFX's Avatar
H-T White Ops
Goo Gone and degreaser won't help.
It takes weeks to burn off (again, from my Google search).
You might want to use a razor blade to scrape off the top few layers and then let it burn the rest off.
Just removing it isn't going to help at all though. Keeping it on to let it burn off sounds like a better idea, though if there's as much as you say there is you might want to manually remove some of the plastic.
Old Sep 10, 2010 | 02:03 PM
komat's Avatar
you could get a grinder and grind it all off
Old Sep 10, 2010 | 02:08 PM
i'd put a mask on and hit it with a propane torch if solvents/gasoline wont remove it
Old Sep 10, 2010 | 04:26 PM
donut.'s Avatar
Breathing carbon monoxide is definitely the way to go
Old Sep 10, 2010 | 05:42 PM
TunerN00b's Avatar
I got a cone wedged between the body and the cat, and the heat melted it in place before I could yank it out. Produced a wonderful smell driving home...
Brake cleaner works wonders for dissolving plastic. Consider trying that, but be very careful about the fumes produced if any remaining cleaner is left on the exhaust, so clean it off with lots of water afterward, and don't drive the car until everything has dried.
Old Sep 11, 2010 | 12:59 AM
PowerLeg's Avatar
didn't have time to do any sort of removing. i drove a good few hours today kept hte windows down and tried ot be on the freeway as much as possible and over 4k rpm =\ ears going numb
the burning smell seemed to have lessened slightly... i hope those mad vtaks and high compression raped the plastic lol.
wont have time to check tomorrow either =\
Old Sep 11, 2010 | 05:09 AM
EHondaJDM's Avatar
Should've been off after this post...
Old Sep 14, 2010 | 12:17 PM
HECTIC's Avatar
had this happen to me before... i would still catch wiffs of it after a year if i drove long enough..lol
Old Sep 14, 2010 | 12:44 PM
dudesitsjdm's Avatar
take off the exhaust and throw fire cracker's at.
Old Sep 14, 2010 | 12:56 PM
jdmlove2006's Avatar
that will work the best lol
Old Sep 14, 2010 | 07:57 PM
dc2_dude's Avatar
hahahah this thread is halarious.. i really LOL to some of these post. Just spray some brake cleaner on it and use a razor blade ORRRR drive the **** out of it for 5 min. then let it sit in your drive way running for a few then..put some gloves on and take a putty knife or razor blade...boom gone
Old Feb 6, 2011 | 01:53 AM
PowerLeg's Avatar
i'm posting just because i havn't noticed the smell in a long time
vtak musta raped it
Old Feb 6, 2011 | 07:30 AM
Dogginator's Avatar
Daisy... Daisy...
A plastic bag is typically polyethylene. It would be simple to remove with a propane or MAPP gas torch. You also learned that it will burn off on its own over time.
Those of you who suggested solvents to remove polyethylene do not understand chemistry very well.
sohctodohc
11
Mar 26, 2007 11:21 AM
.M.
Mar 13, 2005 10:02 PM
CRXstress
Jun 21, 2004 06:24 PM
JforJonathan
May 12, 2003 12:45 PM
.nate
11
Jul 8, 2002 07:26 PM
